[petsc-dev] DMDA_*PERIODIC and DMDA_XYZGHOSTED
    Matthew Knepley
    knepley at gmail.com
    Wed Mar  2 12:59:59 CST 2011
On Wed, Mar 2, 2011 at 11:29 AM, Ethan Coon <ecoon at lanl.gov> wrote:
> Ok, I've gotten frustrated enough to generalize the DMDA Periodicity to
> allow for periodic, ghosted, or nonghosted individually in each
> dimension.
> The 1D case is done, but one design choice regarding the higher
> dimensional cases that I wanted some advice on.  Is there a reason to
> not use negative indices in the construction of the index sets that
> specify the global-to-local scatter?  In the construction of the
> "to" (local) index set, the STAR_STENCIL case specifically enumerates
> the pattern in both to and from index sets.  However, it would much
> cleaner to:
If its simpler, I say use it. The -1's could be easily compressed out with
any pass.
   Matt
> 1. specify the full local domain in the "to" local IS
> 2. generate the "from" IS with -1 in the corners (and in the ghost cells
> that have no corresponding global entry, as they are off the domain, in
> the DMDA_XYZGHOSTED case).
> With -1 in the IS, there would be no communication done, but the IS
> would be slightly larger.  Is the overhead associated with negative
> indices nontrivial?
> Ethan
> On Tue, 2010-12-07 at 15:41 -0700, Ethan Coon wrote:
> > On Tue, 2010-12-07 at 13:45 -0600, Barry Smith wrote:
> > > DMDA_XYZGHOSTED does not exist for 2d and 3d it was added, I'm
> guessing, as an experiment and was never in the initial design of DMDA. To
> fully support it one needs to go back tot he design of DMDA and see how to
> have it properly done and not just bolt it on.  Some people like to use
> these types of ghost nodes so I agree it is a useful thing to have but who
> is going to properly add it?
> > At some point in the not-too-distant future I'll get frustrated enough
> > to look into this, but I don't have the time at the moment.  At first
> > glance it looks like:
> > - Ensure DMDA{X,Y,Z}Periodic() macros are used everywhere instead of
> > direct comparisons to dd->wrap (they aren't used everywhere currently).
> > - Define macros DMDA{X,Y,Z}Ghosted() to (in some places) replace
> > DMDA{X,Y,Z}Periodic() and then choosing the appropriate macro in the
> > right places.
> > - This probably doesn't merit a change in the DMDACreate* API (it would
> > affect a very large amount of user code).  The most obvious alternative
> > to an API change would be a larger, somewhat convoluted enum for the
> > PeriodicType (DMDA_XPERIODIC_YGHOSTED, DMDA_XYGHOSTED, etc) which could
> > at least be made backward compatible.
> > At least all of the functionality should be there already (since it's
> > needed in the periodic case)... it's just higher level code that would
> > need to change.
> > Ethan
> > > On Dec 7, 2010, at 1:30 PM, Jed Brown wrote:
> > > > On Tue, Dec 7, 2010 at 20:21, Ethan Coon <ecoon at lanl.gov> wrote:
> > > > 'd like a DA where there are ghost cells on every boundary, and some
> of
> > > > those ghost cells (but not all) are filled in with periodic values.
> > > > It would be useful to people doing explicit stuff if there was a way
> to get ghost nodes in the local vector without implying periodic
> communication (and weird coordinate management).
> > > > A related issue for purely explicit is to have a way to VecAXPY
> without needing to copy to and from a global vector.  (TSSSP has low-memory
> schemes, paying for an extra vector or two is actually significant in that
> context, and (less significant) I'm certain I can cook up a realistic
> benchmark where the memcpy costs more than 10%.)  I think I know how to
> implement this sharing transparently (more-or-less using VecNest) so we
> could make it non-default but be able to activate it at runtime.
> > >    Why can you not use VecAXPY() on the local Vecs?
> > >    Barry
> > > > Jed
> Ethan Coon
> Post-Doctoral Researcher
> Applied Mathematics - T-5
> Los Alamos National Laboratory
> 505-665-8289
> http://www.ldeo.columbia.edu/~ecoon/
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110302/dabc093e/attachment.html>
