[petsc-dev] About PreLoad
Barry Smith
bsmith at mcs.anl.gov
Thu Jun 30 20:49:04 CDT 2011
PreLoadStage((PETSC_TRUE, "B"), doesn't take a PetscBool argument.
src/snes/examples/tutorials/ex19.c uses these preload macros and does produce a table of the operations done. What is different in your code?
Barry
On Jun 30, 2011, at 5:47 PM, Ryan Yan wrote:
> Dear All,
> I am using a developer version of PETSc code to test a solver code.
> The code loads a matrix, and solves the matrix by method
> A first and then method B. In each method of A and B, I setup KSP, solve,
> and then destroy KSP. So in this process, I set up KSP twice and destroy
> the KSP object twice.
> I am using the PreLoadxxx to do the profiling but seems like part of the
> profiling information is missing.
> PreLoadBegin(PETSC_TRUE, "A"),
> PreLoadEnd()
> The missing part is:
> Event Count Time (sec) Flops --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
> --- Event Stage 0: Main Stage
> --- Event Stage 1: A
> --- Event Stage 2: B
> Is there any way to workaround this?
> Many thanks,
> Yan
