[petsc-dev] Some warning messages.
    Satish Balay
    balay at mcs.anl.gov
    Tue Jun 28 15:48:13 CDT 2011
I meant copy/paste/modify what you see on screen:
i.e You see:
cc -o pcmhd1qsd3.o -c -fast -mp
-I/global/u2/x/xyuan/Software_HOPPER/petsc-dev/include
-I/global/u2/x/xyuan/Software_HOPPER/petsc-dev/arch-cray-xt6-pkgs-opt/include
-I/opt/cray/udreg/2.2-1.0301.2966.16.2.gem/include
-I/opt/cray/ugni/2.1-1.0301.2967.10.23.gem/include
-I/opt/cray/pmi/2.1.1-1.0000.8296.10.8.gem/include
-I/opt/cray/dmapp/3.0-1.0301.2968.22.24.gem/include
-I/opt/cray/xpmem/0.1-2.0301.25333.20.2.gem/include
-I/opt/cray/mpt/5.2.1/xt/gemini/mpich2-pgi/include
-I/opt/cray/mpt/5.2.1/xt/gemini/sma/include
-I/opt/xt-libsci/10.5.01/pgi/include -I/usr/include/alps
-I/opt/pgi/11.2.0/linux86-64/11.2/include
-I/opt/cray/xe-sysroot/3.1.61.securitypatch.20110308/usr/include  -D__INSDIR__=
pcmhd1qsd3.c
So you would copy/paste this on to bash - and modify as follows - and run it..
[instead of running make]
cc -o pcmhd1qsd3.o -c -mp
pcmhd1qsd3.c
This is just to debug the reason for the hang you are encountering
when compling this sourcefile.
Satish
On Tue, 28 Jun 2011, Rebecca Xuefei Yuan wrote:
> Dear Satish,
> Thanks very much for your kind reply.
> I have my makefile :
> PETSC_ARCH = arch-cray-xt6-pkgs-opt
> include ${PETSC_DIR}/conf/variables
> include ${PETSC_DIR}/conf/rules
> include ${PETSC_DIR}/conf/test
> CLINKER = cc
> pcmhd1qsd3:     pcmhd1qsd3.o chkopts
>        -${CLINKER} -v -o pcmhd1qsd3.exe pcmhd1qsd3.o   ${PETSC_SNES_LIB}
> -lpgf90rtl
> Which option indicates for -fast?
> I am not sure I understand the way this makefile do.
> For example, if I have "module load petsc" on Hopper, I only need to do
> cc -o hello.exe hello.c
> to complete the make, but as I would like to use local petsc-dev, I use the
> above makefile. Is this a right way to do so?
> Thanks very much!
> Rebecca
> Quoting Satish Balay <balay at mcs.anl.gov>:
> > > Hello all,
> > > I have installed petsc-dev on Hopper, and when I try to run  examples, I
> > > found
> > > there are some warning messages during make, shall I ignore them?
> > > newcouple/trunk> make ex19
> > > cc -o ex19.o -c -fast -mp
> > > -D__INSDIR__=
> > > ex19.c
> > > cc -v -o ex19.exe ex19.o
> > > -L/global/u2/x/xyuan/Software_HOPPER/petsc-dev/arch-cray-xt6-pkgs-opt/lib
> > > -lpetsc
> > > -Wl,-rpath,/global/u2/x/xyuan/Software_HOPPER/petsc-dev/arch-cray-xt6-pkgs-opt/lib
> > > -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
> > > -lsuperlu_dist_2.5
> > > -lparmetis -lmetis -L/opt/acml/4.4.0/pgi64/lib -lacml -lacml_mv -ldl
> > > /opt/cray/xt-asyncpe/4.9/bin/cc: INFO: Compiling for compute nodes running
> > > CLE.
> > > /usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o
> > > /opt/pgi/11.2.0/linux86-64/11.2/lib/trace_init.o
> > > /usr/lib64/gcc/x86_64-suse-linux/4.3/crtbeginT.o
> > > /opt/pgi/11.2.0/linux86-64/11.2/lib/initmp.o -m elf_x86_64 -dynamic-linker
> > > /lib64/ld-linux-x86-64.so.2 /opt/pgi/11.2.0/linux86-64/11.2/lib/pgi.ld
> > > -L/opt/cray/udreg/2.2-1.0301.2966.16.2.gem/lib64
> > > -L/opt/cray/ugni/2.1-1.0301.2967.10.23.gem/lib64
> > > -L/opt/cray/pmi/2.1.1-1.0000.8296.10.8.gem/lib64
> > > -L/opt/cray/dmapp/3.0-1.0301.2968.22.24.gem/lib64
> > > -L/opt/cray/xpmem/0.1-2.0301.25333.20.2.gem/lib64
> > > -L/opt/cray/mpt/5.2.1/xt/gemini/mpich2-pgi/lib
> > > -L/opt/cray/mpt/5.2.1/xt/gemini/sma/lib64 -L/opt/xt-libsci/10.5.01/pgi/lib
> > > -L/opt/cray/portals/default/lib64
> > > -L/opt/cray/xe-sysroot/3.1.61.securitypatch.20110308/usr/lib64
> > > -L/opt/cray/xe-sysroot/3.1.61.securitypatch.20110308/lib64
> > > -L/opt/cray/xe-sysroot/3.1.61.securitypatch.20110308/usr/lib/alps
> > > -L/usr/lib/alps -L/opt/pgi/11.2.0/linux86-64/11.2/lib -L/usr/lib64
> > > -L/usr/lib64/gcc/x86_64-suse-linux/4.3 -Bstatic ex19.o -lpetsc -rpath
> > > -lsuperlu_dist_2.5
> > > -lparmetis -lmetis -lacml -lacml_mv -ldl
> > > -rpath=/opt/cray/udreg/2.2-1.0301.2966.16.2.gem/lib64
> > > -rpath=/opt/cray/ugni/2.1-1.0301.2967.10.23.gem/lib64
> > > -rpath=/opt/cray/pmi/2.1.1-1.0000.8296.10.8.gem/lib64
> > > -rpath=/opt/cray/dmapp/3.0-1.0301.2968.22.24.gem/lib64
> > > -rpath=/opt/cray/xpmem/0.1-2.0301.25333.20.2.gem/lib64
> > > /opt/cray/atp/1.1.2/lib/atpSigHandler.o --undefined=__atpHandlerInstall
> > > -rpath=/opt/cray/mpt/5.2.1/xt/gemini/mpich2-pgi/lib
> > > -rpath=/opt/cray/mpt/5.2.1/xt/gemini/sma/lib64
> > > -rpath=/opt/xt-libsci/10.5.01/pgi/lib
> > > -rpath=/opt/xt-libsci/default/pgi/lib
> > > -rpath=/opt/cray/portals/default/lib64 -rpath=/usr/lib/alps --start-group
> > > -lscicpp -lstdc++ -lsci_mc12_mp -lmpich -lmpl -lsma -lxpmem -ldmapp -lugni
> > > -lpmi -lalpslli -lalpsutil -ludreg -lpthread --end-group -rpath
> > > /opt/pgi/11.2.0/linux86-64/11.2/lib -o ex19.exe
> > > /opt/pgi/11.2.0/linux86-64/11.2/lib/nonuma.o -lpgmp -Bdynamic -Bstatic
> > > -lpthread -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lnspgc
> > > -lpgc
> > > -lrt -lpthread -lm -lgcc -lgcc_eh -lc -lgcc -lgcc_eh -lc
> > > /usr/lib64/gcc/x86_64-suse-linux/4.3/crtend.o /usr/lib64/crtn.o
> > > /global/u2/x/xyuan/Software_HOPPER/petsc-dev/arch-cray-xt6-pkgs-opt/lib/libpetsc.a(fuser.o):
> > > In function `PetscGetUserName':
> > > /global/u2/x/xyuan/Software_HOPPER/petsc-dev/src/sys/utils/./fuser.c:61:
> > > warning: Using 'getpwuid' in statically linked applications requires at
> > > runtime the shared libraries from the glibc version used for linking
> > > /global/u2/x/xyuan/Software_HOPPER/petsc-dev/arch-cray-xt6-pkgs-opt/lib/libpetsc.a(send.o):
> > > In function `PetscOpenSocket':
> > > /global/u2/x/xyuan/Software_HOPPER/petsc-dev/src/sys/viewer/impls/socket/./send.c:98:
> > > warning: Using 'gethostbyname' in statically linked applications requires
> > > at
> > yes you can ignore these message.
> > > Moreover, when I try to make my new code (on Hopper), it halts without any
> > > messages, like the screen freeze as
> > > newcouple/trunk> make pcmhd1qsd3
> > > -D__INSDIR__=
> > > pcmhd1qsd3.c
> > > Any suggestions why this happens?
> > I guess the optimizer is taking forever. You can try compiling this
> > code without -fast and see if it completes. i.e manually copy/paste
> > the compile command and modify..
> > Satish
> > > Thanks very much!
> > > Rebecca
> Rebecca Xuefei YUAN
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
