[petsc-dev] data locality issues in PETSc
    Matthew Knepley
    knepley at gmail.com
    Fri Jun 24 16:35:47 CDT 2011
On Fri, Jun 24, 2011 at 11:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Moving this discussion to petsc-dev since it is relevant for much more
> than this one preconditioner.
>  In PETSc the Mat object is responsible for the layout of the matrix
> (graph) data and the Vec object is responsible for the layout of the vector
> data. This will be true within a compute node as it has always been outside
> of the compute nodes. If one uses a DM to create the Mat and Vec objects
> then the DM may decide the data layout (just as it currently does between
> processes) within the node for NUMA reasons (i.e. that touch all business).
>  I think it is ok to assume that the input (on process part of) Mat's and
> Vec's have good data layout across the the node memory (as well as across
> the nodes as you assumed n years ok), if that is not the case then we will
> need to have generic tools to repartition them anyways that would be used in
> a preprocessing step before applying the KSP before the GAMG ever sees the
> data.
>  I don't think you should get too hung up on the multiple thread business
> in your first cut, just do something and it will evolve as we figure out
> what we are doing.
All fast point location algorithms use coarse divisions and then some
resolution step at the end. We could just do the same thing, which
I think is what you propose. I agree that its not a big deal exactly what is
happening on a node (1 threads, 1000 threads, etc.)
   Matt
>   Barry
> On Jun 24, 2011, at 11:17 AM, Mark F. Adams wrote:
> > Folks, I'm looking at designing this GAMG code and I'm running into
> issues that are pretty general in PETSc so I want to bring them up.
> > The setup for these GAMG methods is simplified if subdomains are small.
>  So I'm thinking that just writing a flat program per MPI processes will not
> be good long term.  These issues are very general and they touch on the
> parallel data model of PETSc so I don't want to go off and just do something
> w/o discussing this.
> > Generally as we move to multi/many core nodes, a mesh that is well
> partitioned onto nodes in not good enough.  Data locality in the node needs
> to be addressed and it probably needs to be addressed explicitly.  The GAMG
> algorithm requires finding fine grid points in the coarse grid mesh (and if
> the coarse grid does not cover the fine grid then something has to be done
> like find the nearest coarse grid triangle/tet/element).  Doing this well
> requires a lot of unstructured mesh work and data structures, and it can get
> goopy.  I'd like to simplify this, at least for an initial implementation,
> but I want to build in a good data model for say machines in 5-10 years.
>  THe flat MPI model that I use in Prometheus is probably not a good model.
> > Let me throw out a straw man to at least get the discussion going.  My
> first thought for the GAMG setup is use METIS to partition the local
> vertices into domains of some approximate size (say 100 or 10^D) and have an
> array or arrays of coordinates, for instance, on each node.  Put as much of
> the GAMG setup into an outer loop over the subdomains on a node.  THis outer
> loop could be multi-threaded eventually.  This basically lets GAMG get away
> with N^2 like algorithms because N is an internal parameter (eg, 100), and
> it addresses general data locality issues.  Anyway, this is just a straw
> man, I have not thought this through completely.
> > An exercise that might help to ground this discussion is to think about a
> case study of a "perfect" code in 5-10 years.  GAMG has promise, I think,
> for convective/hyperbolic problems where the geometric coarse functions can
> be a big win.  So perhaps we could think about a PFLOWTRAN problem on a
> domain that would be suitable for GAMG.  Or an ice sheet problem.  THese
> data locality issues should be addressed at the application level if
> feasible, but I don't know what a reasonable model would be.  For instance,
> my model in Prometheus is that the user provides me with a well partitioned
> fine grid matrix.  I do not repartition the fine grid, but I do not make any
> assumptions about data locality within an MPI process.  We may want to
> demand more out of users if they expect to go extreme-scale.  Anyway just
> some thoughts,
> > Mark
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110624/cb845dc1/attachment.html>
