[petsc-dev] Fortran libraries cannot be used with C++ compiler
    Rebecca Xuefei Yuan
    xy2102 at columbia.edu
    Fri Jun 24 14:45:48 CDT 2011
I attached the log file.
Best,
R
Quoting Rebecca Xuefei Yuan <xy2102 at columbia.edu>:
> Hello,
> I tried to configure dev on Hopper, however there are some errors out:
> Software_HOPPER/petsc-dev> ./config/configure.py --with-cc=cc
> --with-fc=ftn --download-mpich=1 download-f-blas-lapack=1
> --download-superlu_dist=1 --download-mumps=1 --download-hypre=1
> --with-fortran-kernels=generic --with-scalar-type=complex
> --download-parmetis=1 --download-scalapack=1 --download-blacs=1
>              Configuring PETSc to compile on your system
> TESTING: checkFortranLibraries from
> config.compilers(config/BuildSystem/config/compilers.py:672)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> Fortran libraries cannot be used with C++ compiler.
>  Run with --with-fc=0 or --with-cxx=0
> Anything wrong with it?
> Shall I attach the log file?
> Thanks very much!
> Rebecca
> Rebecca Xuefei YUAN
> Department of Applied Physics and Applied Mathematics
> Columbia University
> Tel:917-399-8032
> www.columbia.edu/~xy2102
Rebecca Xuefei YUAN
Columbia University
Tel:917-399-8032
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110624/d557839f/attachment.bin>
