[petsc-dev] question about PETSc.Vec.sum()
Manuel Quezada
manuel.quezada at kaust.edu.sa
Tue Jun 21 16:41:13 CDT 2011
Thanks a lot for the advice, it worked nice =)...
I appreciate your help,
Manuel
On Tue, Jun 21, 2011 at 7:59 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Jun 21, 2011 at 18:56, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
>> PETSc could also just provide a VecReduce and VecReduceStride operation,
>> which might simplify the programming effort a bit.
> That would be neat, especially if it used MPI_Op for the reduction. You
> would need MPI-2.2 to have MPI_Reduce_local() for user-defined operations,
> but it would be more flexible and less code than the current approach.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110622/d813b6ee/attachment.html>
