[petsc-dev] indexing for periodic BC
Jed Brown
jed at 59A2.org
Sun Jun 19 08:38:03 CDT 2011
On Fri, Jun 17, 2011 at 23:00, Barry Smith <bsmith at mcs.anl.gov> wrote:
> It is possible that list of elements is not correct for periodic boundary
> conditions; I've never used it. I'm forwarding this to petsc-dev so Matt can
> check it and see if the elements make sense and what indices they routine
> (are the local, global? I don't know) if they are local then maybe you don't
> need to the MatSetValuesStencil() and just call MatSetValuesLocal().
The function returns local indices, so you would use MatSetValuesLocal(). I
put a link to these in the documentation.
But the implementation is not correct for periodic domains. It should not be
a great deal of work to implement. You would just need to teach that
function about the "wrap-around" elements. But this is actually not trivial
for a mapped grid. In no case can you just use the coordinates that were set
on the DMDA, you have to extrapolate. But it's unclear how to extrapolate
for a non-uniform mesh in order to make the periodic problem consistent. I
don't think this is easy to rectify without changing the API for managing
coordinates, but you can certainly make it work for regular Cartesian grids.
By the way, I think the whole premise of DMDAGetElements() is flawed. Shape
functions are not provided so the user has to implement those themselves and
manage consistency. The actual logic inside DMDAGetElements() is really
small compared to defining quadratures and basis functions, so it's no
particular effort for the user to manage it on their own. Additionally,
managing it on their own will perform somewhat better (no intermediate
indexing structures) and gives more flexibility in boundary conditions.
It might not be a bad idea to offer an easy-to-use, first order only,
structured grid FEM API, but this ain't it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110619/96914b8f/attachment.html>
