[petsc-dev] snes examples tutorials ex50.c forgot output files?
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Jun 13 16:36:50 CDT 2011
   Did someone make a bunch of output files for snes/examples/tutorials/ex50.c and forget to hg add them?
Possible problem with ex48_4, diffs above
/usr/bin/diff: output/ex50_1.out: No such file or directory
Possible problem with ex50, diffs above
Possible problem with ex50_2, diffs above
/usr/bin/diff: output/ex50_5.out: No such file or directory
Possible problem with ex50_5   diffs above
Possible problem with ex50_5  -vecscatter_merge  diffs above
Possible problem with ex50_5  -vecscatter_rsend  diffs above
Possible problem with ex50_5  -vecscatter_rsend -vecscatter_merge  diffs above
Possible problem with ex50_5  -vecscatter_ssend  diffs above
Possible problem with ex50_5  -vecscatter_ssend -vecscatter_merge  diffs above
Possible problem with ex50_5  -vecscatter_alltoall  diffs above
Possible problem with ex50_5  -vecscatter_alltoall -vecscatter_merge  diffs above
Possible problem with ex50_5  -vecscatter_alltoall -vecscatter_nopack  diffs above
Possible problem with ex50_5  -vecscatter_alltoall -vecscatter_nopack -vecscatter_merge  diffs above
Possible problem with ex50_5  -vecscatter_window  diffs above
Possible problem with ex50_5  -vecscatter_window -vecscatter_merge  diffs above
/usr/bin/diff: output/ex50_6.out: No such file or directory
Possible problem with ex50_6, diffs above
/usr/bin/diff: output/ex50_fieldsplit_2.out: No such file or directory
Possible problem with ex50_fieldsplit_2, diffs above
/usr/bin/diff: output/ex50_fieldsplit_3.out: No such file or directory
Possible problem with ex50_fieldsplit_3, diffs above
/usr/bin/diff: output/ex50_fieldsplit_4.out: No such file or directory
Possible problem with ex50_fieldsplit_4, diffs above
/usr/bin/diff: output/ex50_composite_fieldsplit.out: No such file or directory
Possible problem with ex50_composite_fieldsplit, diffs above
/usr/bin/diff: output/ex50_composite_fieldsplit_bjacobi.out: No such file or directory
Possible problem with ex50_composite_fieldsplit_bjacobi, diffs above
/usr/bin/diff: output/ex50_composite_fieldsplit_bjacobi_2.out: No such file or directory
Possible problem with ex50_composite_fieldsplit_bjacobi_2, diffs above
/usr/bin/diff: output/ex50_7.out: No such file or directory
Possible problem with ex50_7, diffs above
/usr/bin/diff: output/ex50_8.out: No such file or directory
Possible problem with ex50_8, diffs above
/usr/bin/diff: output/ex50_9.out: No such file or directory
Possible problem with ex50_9, diffs above
/usr/bin/diff: output/ex50_10.out: No such file or directory
Possible problem with ex50_10, diffs above
/usr/bin/diff: output/ex50_14.out: No such file or directory
Possible problem with ex50_14, diffs above
/usr/bin/diff: output/ex50_15.out: No such file or directory
Possible problem with ex50_15, diffs above
/usr/bin/diff: output/ex50_15a.out: No such file or directory
Possible problem with ex50_15a, diffs above
/usr/bin/diff: output/ex50_16.out: No such file or directory
Possible problem with ex50_16, diffs above
/usr/bin/diff: output/ex50_16a.out: No such file or directory
Possible problem with ex50_16a, diffs above
