[petsc-dev] Fix for long-standing bug in	DMMeshRestoreCoordinatesF90 and DMMeshRestoreElementsF90
    Satish Balay
    balay at mcs.anl.gov
    Wed Jun  8 11:08:13 CDT 2011
Looks like the current code is buggy. Pushed the fix to petsc-dev now.
thanks,
Satish
On Wed, 8 Jun 2011, Blaise Bourdin wrote:
> Hi,
> After poking a bit, I found out the bug causing a segfault in the above-mentioned functions. It seems that gfortran will gladly nullify a bogus pointer, whereas ifort can be a bit pickier, hence the bug coming up only with intel compilers.
> Can you check that the following patch makes sense and if so apply it to petsc-dev?
> Thanks,
> Blaise
> --- a/src/dm/impls/mesh/f90-custom/zmeshf90.c	Tue Jun 07 23:08:25 2011 -0500
> +++ b/src/dm/impls/mesh/f90-custom/zmeshf90.c	Wed Jun 08 09:54:14 2011 -0500
> @@ -31,7 +31,7 @@ void PETSC_STDCALL dmmeshrestorecoordina
>   PetscReal *c;
>   *__ierr = F90Array2dAccess(ptr,PETSC_REAL,(void**)&c PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> -  *__ierr = F90Array2dDestroy(&ptr,PETSC_REAL PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> +  *__ierr = F90Array2dDestroy(ptr,PETSC_REAL PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
>   *__ierr = PetscFree(c);
> void PETSC_STDCALL dmmeshgetelementsf90_(DM *dm,F90Array2d *ptr,int *__ierr PETSC_F90_2PTR_PROTO(ptrd))
> @@ -45,7 +45,7 @@ void PETSC_STDCALL dmmeshrestoreelements
>   PetscInt   *v;
>   *__ierr = F90Array2dAccess(ptr,PETSC_INT,(void**)&v PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> -  *__ierr = F90Array2dDestroy(&ptr,PETSC_INT PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> +  *__ierr = F90Array2dDestroy(ptr,PETSC_INT PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
>   *__ierr = PetscFree(v);
> void PETSC_STDCALL dmmeshgetconef90_(DM *dm,PetscInt *p,F90Array1d *ptr,int *__ierr PETSC_F90_2PTR_PROTO(ptrd))
> @@ -56,7 +56,7 @@ void PETSC_STDCALL dmmeshgetconef90_(DM
> void PETSC_STDCALL dmmeshrestoreconef90_(DM *dm,F90Array1d *ptr,int *__ierr PETSC_F90_2PTR_PROTO(ptrd))
> #if 0
> @@ -64,7 +64,7 @@ void PETSC_STDCALL dmmeshrestoreclosuref
>   PetscReal *c;
>   *__ierr = F90Array1dAccess(ptr,PETSC_REAL,(void**)&c PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> -  *__ierr = F90Array1dDestroy(&ptr,PETSC_REAL PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> +  *__ierr = F90Array1dDestroy(ptr,PETSC_REAL PETSC_F90_2PTR_PARAM(ptrd));if (*__ierr) return;
> #endif
