[petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
Boyce Griffith
griffith at cims.nyu.edu
Mon Jun 6 16:06:55 CDT 2011
On 6/6/11 4:59 PM, Jed Brown wrote:
> On Mon, Jun 6, 2011 at 22:49, Boyce Griffith <griffith at cims.nyu.edu
> <mailto:griffith at cims.nyu.edu>> wrote:
> I stash a pointer to the SAMRAI vector object in the PETSc Vec as
> vec->data.
> Great, somewhere in your FormResidual(), you access this data. Otherwise
> there would be no way for you to change the output data (unless you did
> some sort of hidden sharing which would be super fragile). So why not
> have that API increment the state? For example, VecRestoreArray()
> increments state for PETSc vectors. Since everyone accesses the vector
> through this API, they never have to call PetscObjectStateIncrease()
> themselves.
I never call VecGetArray() / VecRestoreArray() --- it doesn't really
make sense here because there is no single array associated with the
data. In fact, the wrapper class sets ops->getarray to PETSC_NULL.
> Why not have your accessor manage the state? This would be the logically
> consistent way to do it.
I agree --- right now, I have a getVector() method but no
restoreVector() method. Probably the right thing to do is to have a
restoreVector() function that updates the state.
> At least when this stuff was first written, the only way to
> interface the SAMRAI vector class with PETSc was to make a new
> "subclass" of Vec.
> This is still a good way as long as SAMRAI is storing the Vec data
> non-contiguously. If it's stored contiguously, then a normal Vec could
> use it. You could use PetscObjectCompose() to attach your SAMRAI
> structure for when you need the "extra" information. Either SAMRAI or
> PETSc could "own" the pointer.
Sadly, SAMRAI data are not contiguous.
-- Boyce
