[petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
Boyce Griffith griffith at cims.nyu.edu
Mon Jun 6 15:41:56 CDT 2011
On 6/6/11 4:31 PM, Jed Brown wrote:
> On Mon, Jun 6, 2011 at 22:21, Boyce Griffith <griffith at cims.nyu.edu
> <mailto:griffith at cims.nyu.edu>> wrote:
>     Could calls to PetscObjectStateIncrease be added to SNES so that
>     they are not needed anywhere in wrapper/application code?
> For the vector?
Yes.
Well, ideally, everything --- Vec's, Mat's, PC's, ... :-)
> The matrix has its state increased in MatAssemblyEnd(). The API is to
> always call MatAssemblyBegin/End even if the specific format doesn't
> "need" it.
At least in my code, and I expect in Bobby's too, all Mat and PC objects
are just shells.  So the only non-PETSc objects are Vec wrapper objects.
At least at some point in history, it was necessary to call
PetscObjectStateIncrease on the "output" vectors in calls to MatVecMult
/ MatVecMultAdd / etc.
Because screwed up norm caching can ruin your day, I use it pretty
liberally.  But because PetscObjectStateIncrease() doesn't appear to be
intended to be used in user code, it can also be a source of headaches
when changing PETSc versions.
-- Boyce
