[petsc-dev] Promote MatShellSetOperation() and MatShellSetContext() to Mat
    Jed Brown
    jed at 59A2.org
    Mon Jun  6 06:48:35 CDT 2011
On Mon, Jun 6, 2011 at 13:44, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> A related matter: should there be a way to reset the MatSetValuesLocal
> method?
PCShellSetOperation() can reset any operation.
> The setting of local values frequently depends on factors other than
> the type of the matrix.
That's what the ISLocalToGlobalMapping is for.
> The default implementation depends only on the class (Mat) rather than
> the type (e.g., MATMPIAIJ)
> of the matrix.
The definition of the "local space" is something that should not depend on
the implementation.
It calls through mat->ops->setvalueslocal, so I don't understand your
concern.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110606/cb8aa178/attachment.html>
