[petsc-dev] valgrind appears to show memory leak related to	PetscViewerBinaryOpen
    Matthew Knepley
    knepley at gmail.com
    Wed Jun  1 11:24:40 CDT 2011
On Wed, Jun 1, 2011 at 11:23 AM, Jed Brown <jed at 59a2.org> wrote:
> On Wed, Jun 1, 2011 at 18:20, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> There is no reason for the existence of PetscViewerBinaryCreate(), I am
>> removing it from PETSc-dev.
> Are you also removing MatCreateSeqAIJ()? Removing it turns one line into
> four and I don't see the benefit. I suspect people are less likely to use
> -viewer_type to change their viewer than -mat_type to change their matrix.
You can still use BinaryOpen()
  Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/47e5ebbe/attachment.html>
