[petsc-dev] valgrind appears to show memory leak related to	PetscViewerBinaryOpen
    Brad Aagaard
    baagaard at usgs.gov
    Wed Jun  1 11:05:49 CDT 2011
Hi all:
Valgrind is suggesting that I may have a memory leak associated with
PetscViewer objects in PyLith. I created a simple example (attached)
that reproduces the valgrind message.
Is there really a memory leak associated with PetscMallocAlign() or is
valgrind just confused?
I also ran the example with the -malloc -malloc_debug -malloc_dump
flags. What do the values in square brackets mean? Does [0] indicate
memory was freed or not freed? The FAQ on use of -malloc doesn't appear
to discuss what the output means.
Logs from running the example in valgrind and with the malloc flags are
also attached.
Brad
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/4576be45/attachment.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/4576be45/attachment-0001.ksh>
Type: text/x-c++src
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/4576be45/attachment.bin>
