[petsc-dev] [petsc-maint #74896] Re: What was the 64-bit problem with pow()?
Matthew Knepley
knepley at gmail.com
Wed Jun 1 07:51:04 CDT 2011
On Wed, Jun 1, 2011 at 7:29 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On May 31, 2011, at 9:56 PM, Matthew Knepley wrote:
> > On Tue, May 31, 2011 at 9:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> Man that PowInt is one ugly mo-fo. Since an int is an int is an int
> why
> >> do you need the PowInt? Why not just caste with (int)? Instead of
> increasing
> >> the complexity of PETSc with PowInt? int is acceptable in PETSc when
> passed
> >> to appropriate system calls that do take an int. The cases PetscMPIInt
> and
> >> PetscBLASInt are marked with special names to make the code clear but I
> >> don't think PowInt is needed.
> > I did not want to downcast because PetscPow() works for (Scalar, Int) and
> > (Scalar, Real) so automatically casting to (int) is not right.
> But that is exactly what the code does, isn't it?
> #if defined(PETSC_USE_64BIT_INDICES)
> typedef int PowInt;
> #else
> typedef PetscInt PowInt;
> #endif
> static PetscScalar CPowF(PetscScalar c,PetscInt p)
> return PetscPowScalar(c,(PowInt)p)/Factorial(p);
> Isn't it casting to PowInt which is int?
Not exactly. If I define
#define PetscPowScalar(a, b) std::pow(a, (int) b)
then this call
PetscPowScalar(2.0, 0.333)
will not work correctly. If I do not, then
PetscPowScalar(2.0, 3)
will fail when using --with-64-bit-indices. The only solution I saw was for
the user
to do the cast explicitly
Matt
> Barry
> > Matt
> >> Barry
> >> On May 30, 2011, at 9:53 AM, Jed Brown wrote:
> >>> On Mon, May 30, 2011 at 16:38, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> You wrote the code that takes PetscInt p!!! If you do not want that,
> >> change it to PetscReal.
> >>> Right, I was relying on standard promotion rules and forgot about
> >> std::pow(scalar, int). The exponent is a loop counter, so it can't
> >> reasonably be made a scalar. This whole thing could be implemented
> without
> >> calling pow() in any form, just multiplication, but it's not in a
> >> performance-sensitive place and I thought the code would be easier to
> read
> >> this way.
> >>> The reason I brought this up is that I thought it was worth
> standardizing
> >> a way to get an integer power (this is a common thing to need in
> adaptive
> >> controllers). Should we add a function like PetscPowRealInt()? This
> seems
> >> ugly, but it's also ugly and confusing to deal with these functions
> >> resolving to quite different things on C versus C++ builds (with the
> usual
> >> variability in C++ compilers). This code is over a year old so it
> shouldn't
> >> have new portability issues. The existence of a new ticket seems like a
> >> defect in the process, but I'm not sure what the best fix is.
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
> why do you need the PowInt? Why not just caste with (int)? Instead of
> increasing the complexity of PETSc with PowInt? int is acceptable in PETSc
> when passed to appropriate system calls that do take an int. The cases
> PetscMPIInt and PetscBLASInt are marked with special names to make the code
> clear but I don't think PowInt is needed.
> > Matt
> > Barry
> reasonably be made a scalar. This whole thing could be implemented without
> performance-sensitive place and I thought the code would be easier to read
> this way.
> standardizing a way to get an integer power (this is a common thing to need
> in adaptive controllers). Should we add a function like PetscPowRealInt()?
> This seems ugly, but it's also ugly and confusing to deal with these
> functions resolving to quite different things on C versus C++ builds (with
> the usual variability in C++ compilers). This code is over a year old so it
> shouldn't have new portability issues. The existence of a new ticket seems
> like a defect in the process, but I'm not sure what the best fix is.
> experiments lead.
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110601/b8ad3466/attachment.html>
