[petsc-dev] [petsc-maint #80371] fix for building errors	related to vecpthread
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Jul 22 13:55:59 CDT 2011
  Satish has updated the repository of BuildSystem to remove all the changes I made yesterday that broke things. Please let petsc-maint know if there are still problems.
   Barry
On Jul 22, 2011, at 1:45 PM, Brad Aagaard wrote:
> On 07/22/2011 11:32 AM, Barry Smith wrote:
>> On Jul 22, 2011, at 12:57 PM, Brad Aagaard wrote:
>>> Hi all:
>>> I encountered some errors when building petsc-dev this morning. After
>>> reverting config/BuildSystem to remove Barry's CUDA/thrust changes so
>>> that CUDA is not enabled by default,
>>     I didn't mean to enable it by default. Could you please tell me what I did and what you did to undo it since I don't want it enabled by default?
> All I did was revert my local config/BuildSystem back to changeset 2684, so something in your changesets 2685 and 2686 resulted in the check for the CUDA compiler being run by default.
> Thanks,
> Brad
