[petsc-dev] new configuration/compile system for PETSc
Dmitry Karpeev karpeev at mcs.anl.gov
Sat Jul 9 19:37:38 CDT 2011
On Sat, Jul 9, 2011 at 7:18 PM, Harald Pfeiffer
<pfeiffer at cita.utoronto.ca> wrote:
> We happen to use Petsc with our own makefiles.  PETSc is compiled entirely
> separately (or we use system-provided PETSc-modules).   We then manually set
> the appropriate include- and library-paths in our makefiles, for example:
> PETSC_INCLUDE = -I$(PETSC_DIR)/include -I$(PETSC_DIR)/$(PETSC_ARCH)/include
> PETSC_LIB = -L$(PETSC_DIR)/$(PETSC_ARCH)/lib -lpetsc -lX11
> other stuff here
> ARCH_INCLUDE = $(PETSC_INCLUDE)  ...
> ARCH_LIB_PARALLEL   = $(HDF_LIB) $(FFTW_LIB) $(PETSC_LIB)  ....
> Not elegant, but has been working like a charm for the last 12 years.
I'm not saying it can't be made to work.
I'm saying it might not be trivial for someone just starting to use
PETSc and not even necessarily
that familiar with make: there are a lot of potential users like that.
 And even for more sophisticated
users it might take a while to work out the kinks.
Dmitry.
> Harald
> On 7/10/11 1:02 AM, Dmitry Karpeev wrote:
>> On Sat, Jul 9, 2011 at 6:42 PM, Jed Brown<jedbrown at mcs.anl.gov>  wrote:
>>> On Sat, Jul 9, 2011 at 18:30, Dmitry Karpeev<karpeev at mcs.anl.gov>  wrote:
>>>>  If a user could write a
>>>> simple foo.py that configured/built their
>>>> favorite package with PETSc as a dependency, they could then proceed
>>>> to modify the FOO code and jack
>>>> PETSc into it.
>>> But this just a different form of asking them to adopt our build system,
>>> except that makefiles are a de-facto standard and our system won't be
>>> familiar to anyone. Any system has to be easily usable from other systems
>>> (at least makefiles, automake, and cmake).
>> Yes, but there is also a practical problem: an engineer or a scientist,
>> not
>> intimately familiar with automake, cmake, etc., has taken the effort
>> to understand
>> PETSc so that our linear solvers can be substituted for FOO's.  How can we
>> make it easier for these people to insert PETSc into their code?  Here
>> I only mean
>> the build process.  Maybe making them write foo.py is not the right
>> approach,
>> but we should have a usable approach (and, maybe, an example of doing it).
>> In particular, is it sufficient to export linklibs, or do we also need
>> to export the
>> compiler (e.g., to ensure consistent Fortrant name mangling)?  There are
>> a good number of Fortran users that want to use PETSc too.
>> Dmitry.
> Harald Pfeiffer
> Assistant Professor
> Cdn. Institute for Theoretical Astrophysics
> University of Toronto
> Tel. ++1 416-978-8497
