[petsc-dev] About PreLoad
    Ryan Yan
    vyan2000 at gmail.com
    Fri Jul  1 09:02:05 CDT 2011
Dear Barry,
In my previous email, that is a typo.
In the actual code, I did use:
PreLoadStage("A");
PreLoadStage("B"),
Ok, I see the difference:
I use the PetscOptionsSetValue("-log_summary",""); after the preloading
section. And so when I submit the job, I did not include the command line
option -log_summary again. This seems having confused the code.
And this behavior causes some of the statistics missing as I reported above.
After remove the function call PetscOptionsSetValue("-log_summary","") in
the
code and use command line option -log_summary. It worked. And all the
information is complete now.
Thanks a lot for the help,
Yan
On Thu, Jun 30, 2011 at 9:49 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> PreLoadStage((PETSC_TRUE, "B"), doesn't take a PetscBool argument.
> src/snes/examples/tutorials/ex19.c uses these preload macros and does
> produce a table of the operations done. What is different in your code?
>   Barry
> On Jun 30, 2011, at 5:47 PM, Ryan Yan wrote:
> > Dear All,
> > I am using a developer version of  PETSc code to test a solver code.
> > The code loads a matrix, and solves the matrix by method
> > A first and then method B. In each method of A and B, I setup KSP, solve,
> > and then destroy KSP. So in this process, I set up KSP twice and destroy
> > the KSP object twice.
> > I am using the PreLoadxxx to do the profiling but seems like part of the
> > profiling information is missing.
> > PreLoadBegin(PETSC_TRUE, "A"),
> > PreLoadEnd()
> > The missing part is:
> > Event                Count      Time (sec)     Flops
>         --- Global ---  --- Stage ---   Total
> >                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
> > --- Event Stage 0: Main Stage
> > --- Event Stage 1: A
> > --- Event Stage 2: B
> > Is there any way to workaround this?
> > Many thanks,
> > Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110701/d5fd82b4/attachment.html>
