[petsc-dev] broke configure removed config.guess and config.sub
    Matthew Knepley
    knepley at gmail.com
    Fri Jan 28 20:04:12 CST 2011
Okay, I pushed. Satish, is there an easy way to send me the nightly builds
every day
for the next week. I want to make sure the shared library stuff is working.
I basically turned off anything I thought we were not using (Alpha, HPUX,
etc). I don't
think we can even test those. I have a list of tests to setup to make some
things work
(IBM, Cygwin, Solaris I think). Getting to them.
   Matt
On Fri, Jan 28, 2011 at 12:04 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Crap I fixed this another way. Will merge.
>    Matt
> On Thu, Jan 27, 2011 at 11:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Thu, 27 Jan 2011, Barry Smith wrote:
>> >    Matt and everyone
>> >     I have intentionally partly broken configure by removing ALL traces
>> of the use of the two horrible horrible bash shell scripts config.guess and
>> config.sub that should have been removed a decade ago and make configure
>> work only on Unix.
>> >    This will break sharedLibraries.py that used hostOSBase which
>> computed using host_os and TetGen.py and Triangle.py that for some strange
>> reason also use it. Best to get rid of hostOSbase completely and do proper
>> tests for different ways of making shared libraries.  Until this is fixed
>> sharedlibraries won't work.
>> for now replaced hostOSbase with sys.platform.
>> Linux,Mac shared now works. Others might need fixing based on this new
>> text string from sys.platform
>> Satish
>> >    Please report or fix all problems that come up ASAP.
>> >    Barry
>> > Yes be pissed at me for ruining your day, but I'm finally lighting the
>> fire under bad configure practices that make it only work on Unix. Cygwin
>> usage must die!
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110128/57ac8169/attachment.html>
