[petsc-dev] builder.py
Satish Balay
balay at mcs.anl.gov
Wed Feb 23 17:17:28 CST 2011
It appers to compile only a bit of fortran modules - and not the c sources for me...
And it leaves arround *.d files in my PETSC_DIR
Satish
Building dependencies in /home/balay/tmp/petsc-dev/include
Building dependencies in /home/balay/tmp/petsc-dev/include/sieve
Building dependencies in /home/balay/tmp/petsc-dev/include/finclude
Building dependencies in /home/balay/tmp/petsc-dev/include/finclude/ftn-auto
Building dependencies in /home/balay/tmp/petsc-dev/include/finclude/ftn-custom
Building dependencies in /home/balay/tmp/petsc-dev/include/private
Building /home/balay/tmp/petsc-dev/src/sys/f90-mod/petscsysmod.F
Building /home/balay/tmp/petsc-dev/src/vec/f90-mod/petscvecmod.F
Building /home/balay/tmp/petsc-dev/src/mat/f90-mod/petscmatmod.F
Building /home/balay/tmp/petsc-dev/src/dm/f90-mod/petscdmmod.F
Building /home/balay/tmp/petsc-dev/src/ksp/f90-mod/petsckspmod.F
Building /home/balay/tmp/petsc-dev/src/snes/f90-mod/petscsnesmod.F
Building /home/balay/tmp/petsc-dev/src/ts/f90-mod/petsctsmod.F
asterix:/home/balay/tmp/petsc-dev>ls
asterix64/ config/ include/ petsckspmod.d petsctsmod.d setup.py* xcode/
bin/ configure* makefile petscmatmod.d petscvecmod.d src/
CMakeLists.txt configure.log@ make.log@ petscsnesmod.d projects/ TAGS
conf/ CTAGS petscdmmod.d petscsysmod.d RDict.log tutorials/
asterix:/home/balay/tmp/petsc-dev>ls asterix64/lib/
libpetsc.a libpetsc-obj/
asterix:/home/balay/tmp/petsc-dev>ar t asterix64/lib/libpetsc.a
petscsysmod.o
petscvecmod.o
petscmatmod.o
petscdmmod.o
petsckspmod.o
petscsnesmod.o
petsctsmod.o
On Wed, 23 Feb 2011, Matthew Knepley wrote:
> I have pushed a new version:
> 1) F90 modules now build correctly
> 2) It has been refactored so that all dependency analysis is done up
> front, and
> all building happens afterwards.
> 3) It could take other dependency trackers (insert your favorite)
> 4) It should be ready for a nightly build
> 5) It should now be possible to use subprocess to completely parallelize
> the build.
> Alert me any problems that come up. It should work for Windows as well, and
> be
> much faster.
> Matt
