[petsc-dev] XXXDestroy() mistaken design in PETSc
Lisandro Dalcin
dalcinl at gmail.com
Tue Feb 15 19:19:01 CST 2011
On 15 February 2011 19:47, Barry Smith <bsmith at mcs.anl.gov> wrote:
> In MPI one calls MPI_Comm_free(&comm) to allow the MPI implementation to set the pointer explicitly to 0 after the object is destroyed.
> In Petsc XXXDestroy() does not pass the pointer (because it seemed too unnatural to me in 1994) thus not allowing 0ing the pointer.
> Was this a bad design decision? Should it be revisited?
This is what I needed in petsc4py, so I had to write my own wrapper
routines: http://code.google.com/p/petsc4py/source/browse/src/PETSc/petscobj.pxi#35
> Barry
> Two use cases
> 1) error detection when someone tries to reuse a freed object
> 2) when removing some objects from a data structure that will be used data one currently needs to do
> XXXXDestroy(mystruct->something);CHKERRQ(ierr); mystruct->something = 0;
> instead of the cleaner XXXDestroy(&mystruct->something);CHKERRQ(ierr);
I think (2) is the more compelling use case...
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
