[petsc-dev] configure issues
    Jed Brown
    jed at 59A2.org
    Wed Feb  9 03:48:50 CST 2011
On Wed, Feb 9, 2011 at 10:26, Matthew Knepley <knepley at gmail.com> wrote:
> 1) This is about fooling with the preprocessor, or I would not need any of
> these goofy names. How can you deny this?
The preprocessor doesn't care what the name of the macro is. Barry's
suggestion was just a way to make it easy for a human to find out where the
macro was set, but at the expense of making the names fragile. I would
rather have the editor be able to navigate using more stable names.
> 2) For test information as well as control flow, I want to stay in Python.
How would you manage, say, the logic around PETSC_USE_X_FOR_DEBUGGER?
Generate the appropriate snippets of code on the Python side? What advantage
to you see to that?
> 3) What do you mean by "link"?
1. From the name of a macro that may be defined in petscconf.h to the test
in configure which is used to decide how to set that macro.
2. From the test in configure to a list of uses on the C side (in a less
brute-force way than grep).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110209/e4dde89c/attachment.html>
