[petsc-dev] documentation webpage is broken
    Satish Balay
    balay at mcs.anl.gov
    Tue Feb  8 16:42:16 CST 2011
On Wed, 9 Feb 2011, Aron Ahmadia wrote:
> link to the source of DMCreateGlobalVector from
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/DM/DMCreateGlobalVector.html
> goes to a broken url:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/dm/da/interface/dm.c.html#DMCreateGlobalVector
> the functional url is:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/dm/interface/dm.c.html
> Also, this really annoys me:
> 234: *PetscErrorCode
> <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode>
> <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/DM/DMCreateGlobalVector.html#DMCreateGlobalVector>(DM
> <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/DM/DM.html#DM>
> dm,Vec <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/Vec/Vec.html#Vec>
> *vec)*235: {
> 239:   (*dm->ops->createglobalvector)(dm,vec);240:   return(0);241: }
pushed a fix - website will get updated tonight. [will see if the links are correct then]
> I went through the documentation to find out how DMCreateGlobalVector
> is implemented.  What's the mnemonic for finding the definition of the
> above function (or I guess, multiple definitions since this appears to
> be a 'virtual function' in C).
tags-search with emacs?
satish
