[petsc-dev] manual page for TSSetIJacobian()
Jed Brown
jed at 59A2.org
Mon Feb 7 17:19:30 CST 2011
pushed
On Mon, Feb 7, 2011 at 23:52, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 7, 2011, at 4:46 PM, Jed Brown wrote:
> > On Mon, Feb 7, 2011 at 23:35, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Well what I want is why is this "the derivative we need"? There is no
> hint as to an explanation why the user providing this quantity has any
> meaning a all. You could just as easily say g_x where g(x) = f(x, a*x^3 +
> 94) and why would that be wrong, while what you write is correct?
> > That is the reason why I like introducing g(x) = f(x,xdot)
> > " where xdot is approximated by the integrator as z+a*x for some a and z
> depending on the integration method, step size, and past states."
> This is exactly the kind of text I want.
> > But perhaps the user (as opposed to someone implementing a new TS)
> doesn't care at all and would be happy to evaluate f_x + a*f_xdot without
> any knowledge of why this beast is relevant.
> The problem is not that you are providing too much information and
> should take some away. The problem is you are not providing enough. Just
> writing G(U) = F(t,U,U0+a*U) is not enough, you need to explain as you have
> above in your sentence that the schemes DO approximate xdot in that manner
> and therefor the Jacobian needed by the schemes is given by dF/dU +
> a*dF/dU_t
> Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110208/62787b86/attachment.html>
