[petsc-dev] configure issues
    Jed Brown
    jed at 59A2.org
    Sun Feb  6 00:16:51 CST 2011
Isn't this just making up for the editor (and perhaps static analysis
challenges with Python)? As long as the definition is explicit, grep -r
HAVE_FOO config/ should locate the definition. For the other direction, you
can grep the source tree (fast if it's in memory or indexed). So how about a
couple Emacs functions for this instead of writing fragile file system paths
into the configuration macros?
On Feb 4, 2011 1:03 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
On Feb 3, 2011, at 1:35 PM, Jed Brown wrote:
> On Thu, Feb 3, 2011 at 16:27, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Then you are not going to like my next idea. I think that "configure"
>> tests should be imbedded directly into the source code and evaluated at
>> compile time to determine what gets built etc. In other words no
distinction
>> between configure and build time :-).
> How to handle tests that need to actually be executed, in a batch
> environment?
>> This also eliminates the possibility of "incorrect semantic information
in
>> comments" since the comments won't be "requires X Y and Z" but instead
the
>> actual tests. Having the test code for a functionality being in a
different
>> place than the use of a functionality is not a good model (the obvious
>> problem with what I say is that the use might be in 50 places so should I
>> have the same test in 50 places?)
> And should the test be executed in all 50 places, or should the result be
> cached? Since C code is context dependent, it would be hard to prove that
it
> was actually the same test in all 50 places, even if it resided in a
common
> header.
  Yes directly imbedding the tests is probably not practical but how about a
naming convention that points directly to the test from the source. Now
sometimes one has to hunt around to find the test associated with a
particular #if since they could be in some many locations. For example
instead of
#if defined(PETSC_HAVE_FOO)     where is the test of foo
have
#if
defined(PETSC_HAVE_FOO_BUILDSYSTEM_CONFIG_MATTSCRAZYFILE_MATTSCRAZYMETHODINTHATFILE)
 now I can always go directly to the test.  Ideally the links would be
bi-directional but that is hard.
 Barry
> Configure is only slow because it has grown into this monster over time; a
complete refactoring should bring it down to barely a minute or so.
> Even a minute is a long time compared to 3 seconds which is what an
incremental build with a couple new/modified implementation files should
take.
> But configure needs to run a lot of tests which involves invoking the
compiler a lot of times (it needs to run the compiler on tiny test programs
to generate understandable errors as soon as possible, squashing it together
into a big compilation later is bad because errors become confusing). I'm
not sure that <1 minute is achievable, but I hope it is.
compile time to determine what gets built etc. In other words no distinction
environment?
> This also eliminates the possibility of "incorrect semantic information in
comments" since the comments won't be "requires X Y and Z" but instead the
actual tests. Having the test code for a functionality being in a different
cached? Since C code is context dependent, it would be hard to prove that it
was actually the same test in all 50 places, even if it resided in a common
header.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110206/d9c5614b/attachment.html>
