[petsc-dev] controlling vector values while doing matrix free operations
Wed Dec 14 16:14:34 CST 2011
On Wed, Dec 14, 2011 at 4:07 PM, Philip, Bobby <philipb at ornl.gov> wrote:
> Hi:
> When doing the following operation in PETSc using FD approximations to a
>  Jacobian vector product
> J'(u)*a = [J(u+h*a) - J(u)]/h
Usually, we would put in F where you have J.
> is there a way for the user to specify that the entries of u+h*a cannot be
> negative for example?
> Browsing the PETSc documentation it was not obvious whether I could do
> this.
You can do whatever you want in your F function, but you should really
investigate SNESVI if
you have bounds on your variables.
     Matt
> Thanks,
> Bobby
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111214/b431a8d7/attachment.html>
