[petsc-dev] Error during compiling petsc-dev with Fortran
Alexander Grayver agrayver at gfz-potsdam.de
Wed Dec 7 04:33:06 CST 2011
Matt,
Same is for SNESFASSetType in petscshes.h90
A lot of errors come from petscts.h90
So I deleted them all. Now it compiles.
Thanks.
Alexander
On 07.12.2011 11:11, Matthew Knepley wrote:
> On Wed, Dec 7, 2011 at 4:01 AM, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     There are more:
> Repeat steps from below. This looks like test code.
>    Matt
>     [  0%] Building Fortran object
>     CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o
>     /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1058):
>     error #5082: Syntax error, found END-OF-STATEMENT when expecting
>     one of: ( % : . = =>
>            MatTransposeColoring c ! MatTransposeColoring
>     /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1063):
>            MatTransposeColoring coloring ! MatTransposeColoring
>     /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1070):
>            MatTransposeColoring matcoloring ! MatTransposeColoring
>     /home/lib/petsc-dev/include/finclude/ftn-auto/petscmat.h90(1079):
>            MatTransposeColoring color ! MatTransposeColoring
>     error #6622: This statement is invalid in an INTERFACE block.
>     error #6218: This statement is positioned incorrectly and/or has
>     syntax errors.
>     syntax errors.
>     syntax errors.
>     syntax errors.
>     compilation aborted for
>     /home/lib/petsc-dev/src/mat/f90-mod/petscmatmod.F (code 1)
>     make[5]: ***
>     [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o] Error 1
>     make[4]: ***
>     [CMakeFiles/petsc.dir/src/mat/f90-mod/petscmatmod.F.o.provides]
>     Error 2
>     make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
>     make[2]: *** [all] Error 2
>     On 07.12.2011 10:39, Matthew Knepley wrote:
>>     On Wed, Dec 7, 2011 at 3:33 AM, Alexander Grayver
>>         Hi Matt,
>>         Unfortunately I don't have Mercurial installed on the cluster
>>         (will negotiate it with admin soon), so I downloaded tarball.
>>         Is there a simple patch for that?
>>     1) Just install it to your home dir. Its very small
>>     2) Go to include/finclude/ftn-auto/petscviewer.h90, remove lines
>>     88--94
>>       Matt
>>         Regards,
>>         Alexander
>>         On 07.12.2011 10:32, Matthew Knepley wrote:
>>>         On Wed, Dec 7, 2011 at 3:23 AM, Alexander Grayver
>>>         wrote:
>>>             Hi dev-team,
>>>             Trying to compile petsc-dev with IFC 11.1 I got:
>>>             CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o
>>>             /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/include/finclude/ftn-auto/petscviewer.h90(91):
>>>             expecting one of: ( % : . = =>
>>>                   PetscViewerVTKWriteFunction func !
>>>             block.
>>>             and/or has syntax errors.
>>>             /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev/src/sys/f90-mod/petscsysmod.F
>>>             (code 1)
>>>             make[5]: ***
>>>             [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o]
>>>             Error 1
>>>             make[4]: ***
>>>             [CMakeFiles/petsc.dir/src/sys/f90-mod/petscsysmod.F.o.provides]
>>>             Error 2
>>>             How it can be fixed?
>>>         Pull, make allfortranstubs, and the build again.
>>>            Matt
>>>             Thanks in advance.
>>>             Regards,
>>>             Alexander
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111207/ebdb4f45/attachment.html>
