[petsc-dev] broken builds
Dmitry Karpeev
karpeev at mcs.anl.gov
Tue Aug 30 14:37:11 CDT 2011
Is there a decent package manager we can simply use or adapt for our
purposes (written in Python, of course)?
I'm guessing the answer is "No", but I thought I'd ask anyway.
Dmitry.
On Tue, Aug 30, 2011 at 2:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 30 Aug 2011, Jed Brown wrote:
> > On Tue, Aug 30, 2011 at 14:24, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > The Satish way (which is always the correct way) is to do rm -rf
> > > ${PETSC_ARCH} and then run ./configure again.
> > Yes, but the run-time of this operation is 2^{1 + millions of dollars
> paid
> > for machine} minutes so it clearly won't work at the exascale. You're
> going
> > to be left in the past if you keep thinking like that.
> > More seriously, rm -rf ${PETSC_ARCH} is horrible because you lose
> > reconfigure-$PETSC_ARCH.py if you don't relocate it first.
> Yes - this is one drawback. Also there is another issue that 'rm -rf'
> adresses that --download-package=reinstall can't do easily [without a
> proper traker and uninstaller]
> All --download-package=reinstall can do is install the new one over
> the old one. This can can still break if the new one doesn't
> completely overwrite the old one.
> One example: --download-superlu can change from installing
> -lsuperlu4.1 to -lsuperlu4.2. Perhaps there are other suttle breakage
> senarios aswell..
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110830/bf546870/attachment.html>
