[petsc-dev] broken builds
Jed Brown
jedbrown at mcs.anl.gov
Tue Aug 30 14:15:27 CDT 2011
On Tue, Aug 30, 2011 at 14:08, Barry Smith <bsmith at mcs.anl.gov> wrote:
> First he made the reasonable suggestion of adding feature a, then since
> that worked feature b, then why not c and d, by the time he got to q they
> were draining in complexity, nobody understood the software anymore and
> random things broke all the time.
The concept of a package manager, while apparently lost on Apple, is
well-established. These have a few functions:
install
upgrade
rebuild*
uninstall
*If the package is binary-only, then "upgrade" is needed if the ABI of a
dependency changes. If the package is built from source, then "rebuild" is
needed in this case.
PETSc --download-* provides only part of what a package manager does, but I
contend that "if you want to do X, find and delete a magic file named
hash(X), with poorly-documented hash() and run a command that does lots of
other things too" is not a more robust system.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110830/175aac44/attachment.html>
