[petsc-dev] broken builds
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Aug 30 14:04:13 CDT 2011
On Tue, Aug 30, 2011 at 14:01, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Make sure you rm ${PETSC_ARCH}/conf/prometheus before running. Removing the
> external package is not enough to force a rebuild.
Yeah, I suspect this was the issue because I fresh build worked fine for me.
How about --download-package=rebuild actually rebuilding the package and
then setting plain --download-package in reconfigure-arch.py? Then maybe
--rebuild-externalpackages apply the same stunt to all --download packages?
It's lame to have to delete these package files manually and there isn't
even a nice way to glob them.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110830/2b278e94/attachment.html>
