[petsc-dev] configure error
Mark F. Adams
mark.adams at columbia.edu
Thu Aug 25 16:14:22 CDT 2011
I'm getting this error in a Cray:
madams/petsc-dev-new> ./cray-xe6-dbg.py
Configuring PETSc to compile on your system
CONFIGURATION CRASH (Please send configure.log to petsc-maint at mcs.anl.gov)
'Configure' object has no attribute 'f2cblaslapack'
File "/global/u2/m/madams/petsc-dev-new/config/configure.py", line 269, in petsc_configure
framework = config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:], loadArgDB = 0)
File "/global/u2/m/madams/petsc-dev-new/config/BuildSystem/config/framework.py", line 110, in __init__
self.createChildren()
File "/global/u2/m/madams/petsc-dev-new/config/BuildSystem/config/framework.py", line 316, in createChildren
self.getChild(moduleName)
File "/global/u2/m/madams/petsc-dev-new/config/BuildSystem/config/framework.py", line 301, in getChild
config.setupDependencies(self)
File "/global/u2/m/madams/petsc-dev-new/config/PETSc/Configure.py", line 76, in setupDependencies
framework.require('PETSc.utilities.scalarTypes', self.f2cblaslapack)
madams/petsc-dev-new> cat configure.log
Pushing language C
Popping language C
Pushing language CUDA
Popping language CUDA
Pushing language Cxx
Popping language Cxx
Pushing language FC
Popping language FC
This is my script:
#!/usr/bin/python
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--COPTFLAGS=-mp -g',
'--CXXOPTFLAGS=-mp -g',
'--FOPTFLAGS=-mp -g',
'--download-blacs',
'--download-triangle',
'--download-parmetis',
'--download-f-blas-lapack=1',
'--download-hypre=1',
'--with-cc=cc -g',
'--with-clib-autodetect=0',
'--with-cxx=CC -g',
'--with-cxxlib-autodetect=0',
'--with-debugging=1',
'--with-fc=ftn',
'--with-fortranlib-autodetect=0',
'--with-mpiexec=/usr/common/acts/PETSc/3.1/bin/mpiexec.aprun',
'--with-shared-libraries=0',
'--with-x=0',
'PETSC_ARCH=cray-xe6-dbg',
configure.petsc_configure(configure_options)
Any ideas?
