[petsc-dev] hg problem
Jed Brown
jedbrown at mcs.anl.gov
Wed Aug 24 19:45:29 CDT 2011
On Wed, Aug 24, 2011 at 19:16, Mark F. Adams <mark.adams at columbia.edu>wrote:
> I'm stuck. I seem to have some file that I know nothing about:
> examples/tutorials> hg status -m
> M src/dm/impls/iga/iga.c
> that seems to be holding me up from doing just about anything with hg.
> I've tried reverting it with not luck.
hg diff -- to see if there is anything you want to keep
hg revert src/dm/impls/iga/iga.c -- to discard those changes
hg update -C -- to discard any changes in the current working tree and
update to the given revision (tip, by default)
If you have a problem with these, paste the full output.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110824/e3508fc9/attachment.html>
