[petsc-dev] MUMPS-4.10.0 and ParMetis-4.0
Jed Brown
jedbrown at mcs.anl.gov
Tue Aug 23 23:35:59 CDT 2011
On Tue, Aug 23, 2011 at 23:14, Keita Teranishi <keita at cray.com> wrote:
> I’d like to know if you are going to support MUMPS-4.10.0
This was done in May.
> and ParMetis-4.0
We are working on this.
> in the next release of PETSc? If so, what build configuration you will set
> for these two packages? In particular, I am interested in the indexing
> scheme of ParMetis-4.0 as it supports both 32 and 64 bit integers.
Presumably the same as PetscInt (see --with-64-bit-indices).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110823/fceea704/attachment.html>
