[petsc-dev] PETSC_UNUSED broken needs repair
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Sun Aug 21 04:15:05 CDT 2011
You would be surprised at how many places this works:
http://www.agroman.net/corkscrew/
(tunnel SSH traffic over an enforced HTTP proxy)
A
On Sun, Aug 21, 2011 at 11:53 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Aug 21, 2011 at 10:48 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Aug 21, 2011 at 4:47 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Matt,
>>> How do I fix this? You want a release, you have to help us with all
>>> these bugs.
> Crap. 22 is not open in Schipol. I will push when I get to Oslo. Or stick
> in those 2 lines
> and push it before I get there.
> Thanks,
> Matt
>> Okay, I will explain the fix and push it. You are only getting a warning
>> for this missing
>> attribute, and we agreed not to fail on warnings. However, we do search
>> for particular
>> warnings and fail. This logic is in BuildSystem/config/setCompilers.py:870
>> def containsInvalidFlag(self, output):
>> '''If the output contains evidence that an invalid flag was used,
>> return True'''
>> if (output.find('Unrecognized command line option') >= 0 or
>> output.find('Unrecognised command line option') >= 0 or
>> output.find('unrecognized command line option') >= 0 or
>> output.find('unrecognized option') >= 0 or output.find('unrecognised
>> option') >= 0 or
>> output.find('not recognized') >= 0 or output.find('not
>> recognised') >= 0 or
>> output.find('unknown option') >= 0 or output.find('unknown flag')
>> >= 0 or output.find('Unknown switch') >= 0 or
>> output.find('ignoring option') >= 0 or output.find('ignored') >= 0
>> or
>> output.find('argument unused') >= 0 or
>> # When checking for the existence of 'attribute'
>> output.find('is unsupported and will be skipped') >= 0 or
>> output.find('illegal option') >= 0 or output.find('Invalid
>> option') >= 0 or
>> (output.find('bad ') >= 0 and output.find(' option') >= 0) or
>> output.find('linker input file unused because linking not done')
>> >= 0 or
>> output.find('PETSc Error') >= 0 or
>> output.find('Unbekannte Option') >= 0 or
>> output.find('no se reconoce la opci') >= 0) or output.find('non
>> reconnue') >= 0:
>> return 1
>> return 0
>> Thanks,
>> Matt
>>> Barry
>>> On Aug 20, 2011, at 9:43 PM, Jed Brown wrote:
>>> > On Thu, Aug 18, 2011 at 18:15, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> > It happily sets the attribute even though the attribute does not
>>> exist.
>>> > Well, you wrote that code. ;-)
>>> > I think you only need checkCompile() and I guess it should check for
>>> warnings about unsupported attributes.
>>> > TEST configureUnused from
>>> PETSc.Configure(/export/home/petsc/petsc-dev-3/config/PETSc/Configure.py:528)
>>> > TESTING: configureUnused from
>>> > Sees if __attribute((unused)) is supported
>>> > Pushing language Cxx
>>> > sh: /export/home/petsc/soft/mpich2-1.2.1p1/bin/mpicxx -c -o
>>> /tmp/petsc-VAqamh/PETSc.Configure/conftest.o
>>> -I/tmp/petsc-VAqamh/config.setCompilers -I/tmp/petsc-VAqamh/config.compilers
>>> -I/tmp/petsc-VAqamh/config.functions -I/tmp/petsc-VAqamh/config.types
>>> -I/tmp/petsc-VAqamh/PETSc.utilities.missing
>>> -I/tmp/petsc-VAqamh/config.libraries -I/tmp/petsc-VAqamh/PETSc.Configure
>>> -I/tmp/petsc-VAqamh/PETSc.utilities.scalarTypes -g
>>> /tmp/petsc-VAqamh/PETSc.Configure/conftest.cc
>>> > Executing: /export/home/petsc/soft/mpich2-1.2.1p1/bin/mpicxx -c -o
>>> > sh:
>>> > Possible ERROR while running compiler: error message =
>>> {"/tmp/petsc-VAqamh/PETSc.Configure/conftest.cc", line 3: Warning: attribute
>>> unused is unsupported and will be skipped..
>>> > 1 Warning(s) detected.
>>> > Source:
>>> > #include "confdefs.h"
>>> > #include "conffix.h"
>>> > __attribute((unused)) static int myfunc(void){ return 1;}
>>> > int main() {
>>> > int i = myfunc();
>>> > return 0;
>>> > Pushing language CXX
>>> > Popping language CXX
>>> > sh: /export/home/petsc/soft/mpich2-1.2.1p1/bin/mpicxx -o
>>> /tmp/petsc-VAqamh/PETSc.Configure/conftest -g
>>> /tmp/petsc-VAqamh/PETSc.Configure/conftest.o -ldl
>>> > Executing: /export/home/petsc/soft/mpich2-1.2.1p1/bin/mpicxx -o
>>> > sh:
>>> > Defined "UNUSED" to "__attribute((unused))"
>>> > Popping language Cxx
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110821/3f701748/attachment.html>
