[petsc-dev] To add a PETSc dependent package to PETSc as an external package.
Xiaoye S. Li
xsli at lbl.gov
Wed Aug 17 16:14:10 CDT 2011
Ichi,
Can you please sned a tarball of the latest code to petsc-maint?
Barry,
Please install the hook to PETSc's development branch, but not for
distribution. We are still waiting for the LBL's mBSD license before
release.
Sherry
On Wed, Aug 17, 2011 at 1:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Rebecca,
> It would probably be best if you email to petsc-maint the PDSLin tarball
> so we can look at the PDSlin structure and come up with the best way to
> proceed. The way to handle the packaging will depend on how PDSLin interacts
> with PETSc.
> Thanks
> Barry
> On Aug 17, 2011, at 3:19 PM, Xuefei (Rebecca) Yuan wrote:
> > Dear all,
> > We are trying to add a PETSc dependent package called PDSLin to PETSc as
> an external package. PDSLin is a hybrid linear solver and we would like to
> have it been imported to PETSc as SuperLU_DIST used to be, and it provides
> an alternative way to solving a linear system in parallel.
> > Even though the package has not been released yet (should be released
> soon) and it is under testing for some problems, we are still interesting in
> putting it as an external package to PETSc for now.
> > I did some search of the old threads to the petsc-dev team and there is a
> request from Lious for the PaStiX a few years ago.
> > My understanding to add a package is the following steps:
> > 1) create a python code called "PDSLin.py" under
> /petsc-dev/config/PETSc/packages
> > 2) write an interface file between PETSc and PDSLin.
> > As PDSLin is very similar to SuperLU_DIST, and it also depending on PETSc
> (similar to Prometheus), the PDSLin.py is created based on SuperLU_DIST.py
> and Prometheus.py.
> > Before putting the interface file in some places under petsc-dev
> directory, would you please help me understand how those option calls go to
> this interface file?
> > a) am I missing another file to create/modify to have those options
> connected to PDSLin in a very similar way to SuperLU_DIST?
> > b) do I have some flexibility to add more options called from PETSc to
> this package?
> > Moreover, I am not sure how to put the interface file in the dev package.
> > c) where shall it go? The SuperLU_DIST is located at
> > ./src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
> > shall I put it as
> > ./src/mat/impls/aij/mpi/pdslin/pdslin.c ?
> > d) what is the rule of writing this interface file?
> > In superlu_dist.c, the extern functions are
> > extern PetscErrorCode MatFactorInfo_SuperLU_DIST(Mat,PetscViewer);
> > extern PetscErrorCode MatLUFactorNumeric_SuperLU_DIST(Mat,Mat,const
> MatFactorInfo *);
> > extern PetscErrorCode MatDestroy_SuperLU_DIST(Mat);
> > extern PetscErrorCode MatView_SuperLU_DIST(Mat,PetscViewer);
> > extern PetscErrorCode MatSolve_SuperLU_DIST(Mat,Vec,Vec);
> MatLUFactorSymbolic_SuperLU_DIST(Mat,Mat,IS,IS,const MatFactorInfo *);
> > extern PetscErrorCode MatDestroy_MPIAIJ(Mat);
> > What kind of functions should I have in the interface file for PDSLin?
> > I am not sure if I have stated the problem clearly, in short is that we
> would like to add some package to PETSc but not sure the right way and steps
> to approach the goal.
> > Thanks very much!
> > Best regards,
> > Rebecca
> > Postdoctoral Fellow
> > Lawrence Berkeley National Laboratory
> > Tel: 1-510-486-7031
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110817/79a5816e/attachment.html>
