[petsc-dev] declaring argument as const basic type in PETSc
Matthew Knepley
knepley at gmail.com
Wed Aug 17 14:58:38 CDT 2011
On Wed, Aug 17, 2011 at 9:08 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 17, 2011, at 2:04 PM, Chetan Jhurani wrote:
> >> From: Jed Brown
> >> Sent: Wednesday, August 17, 2011 12:38 PM
> >> To: For users of the development version of PETSc
> >> Subject: Re: [petsc-dev] declaring argument as const basic type in PETSc
> >> On Wed, Aug 17, 2011 at 11:34, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>> But my question remains, should we const declare function arguments?
> >> No, the prototype should never use const for stack arguments (pointer to
> const
> >> is totally different and should be used anywhere that it is correct).
> >> I don't know any responsible libraries that const-ify value parameters
> in
> >> prototypes. I think it most commonly arises from ignorance of, or
> sloppiness
> >> with, the actual semantics of the C language.
> So by the standard a compiler should never bitch if in the function
> definition it is declared const but in the extern prototype it is not
> declared const? (This is an exception to the usual rule that the extern
> arguments should match the definition arguments?)
Just so I understand, this declaration and definition:
void foo(const int a);
void foo(const int a) {
is legal, and would prevent a developer from accidentally assigning to a,
but we are outlawing it. I do not
see the rationale.
Matt
> Thanks
> Barry
> > It is useful to have const pass-by-value parameters in function
> > definitions. Not useful in the function declarations or for the
> > caller.
> > This is so that a developer does not assign to a passed-in int
> > unintentionally. Almost all C and C++ compilers accept it and they
> > error out if one does something like the code below. An exception
> > is old IRIX compilers that emit a warning on using const pass-by-value
> > and said it is meaningless to use them. I disagree.
> > void f(const int n, int* j)
> > *j = n;
> > n = 0; // error
> > Of course it is more useful for preventing bugs in more complex
> > functions.
> > Chetan
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110817/25d6f821/attachment.html>
