[petsc-dev] ts/examples/tutorials/ex11 test garbage?
Richard Katz
richard.katz at earth.ox.ac.uk
Wed Aug 17 07:14:52 CDT 2011
> It shouldn't "crap out", it should reject the step, shorten it, compute a fresh Jacobian (if the Jacobian was being lagged), and try again. Thanks for reminding me that this should be done sooner rather than later.
Jed,
For my uses this is a very important feature.
Two questions:
- Will the step size increase after a shorter step has been successful? Will it go immediately back to the maximum size?
- Will it be possible to set a minimum step size, below which the TSSolve() or TSStep() will "crap out?"
It is obviously important that TS not just chug along without error if a timestep fails.
Cheers
Rich
> Isn't this test data from something that is failing? Should it not be there?
> Yeah, was that example converging when you first created it?
> changeset: 15757:896f032fd4a8
> parent: 15750:1f53ec9d4e00
> user: Barry Smith bsmith at mcs.anl.gov
> date: Fri Apr 23 15:03:44 2010 -0500
> summary: some code cleanup and further work on DMMG version 2
> diff --git a/src/ts/examples/tutorials/ex7.c b/src/ts/examples/tutorials/ex11.c
> copy from src/ts/examples/tutorials/ex7.c
> copy to src/ts/examples/tutorials/ex11.c
> --- a/src/ts/examples/tutorials/ex7.c
> +++ b/src/ts/examples/tutorials/ex11.c
> [changes]
Richard Foa Katz
Dept Earth Sciences, Univ Oxford
http://foalab.earth.ox.ac.uk
