[petsc-dev] Wrapper for WSMP
Jack Poulson
jack.poulson at gmail.com
Tue Aug 16 22:18:16 CDT 2011
On Tue, Aug 16, 2011 at 9:35 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Aug 16, 2011, at 5:14 PM, Jack Poulson wrote:
> > Hello all,
> > I am working on a project that requires very fast sparse direct solves
> and MUMPS and SuperLU_Dist haven't been cutting it. From what I've read,
> when properly tuned, WSMP is significantly faster, particularly with
> multiple right-hand sides on large machines. The obvious drawback is that
> it's not open source, but the binaries seem to be readily available for most
> platforms.
> > Before I reinvent the wheel, I would like to check if anyone has already
> done some work on adding it into PETSc. If not, its interface is quite
> similar to MUMPS and I should be able to mirror most of that code. On the
> other hand, there are a large number of platform-specific details that need
> to be handled, so keeping things both portable and fast might be a
> challenge. It seems that the CSC storage format should be used since it is
> required for Hermitian matrices.
> > Thanks,
> > Jack
> Jack,
> By all means do it. That would be a nice thing to have. But be aware that
> the WSMP folks have a reputation for exaggerating how much better their
> software is so don't be surprised if after all that work it is not much
> better.
Good to know. I was somewhat worried about that, but perhaps it is a matter
of getting all of the tuning parameters right. The manual does mention that
performance is significantly degraded without tuning. I would sincerely hope
no one would out right lie in their publications, e.g., this one:
http://portal.acm.org/citation.cfm?id=1654061
> BTW: are you solving with many right hand sides? Maybe before you muck
> with WSMP we should figure out how to get you access to the multiple right
> hand side support of MUMPS (I don't know if SuperLU_Dist has it) so you can
> speed up your current computations a good amount? Currently PETSc's
> MatMatSolve() calls a separate solve for each right hand side with MUMPS.
> Barry
I will eventually need to solve against many right-hand sides, but for now I
am solving against one and it is still taking too long; in fact, not only
does it take too long, but memory per core increased for fixed problem sizes
as I increase the number of MPI processes (for both SuperLU_Dist and MUMPS).
This was occurring for quasi2d Helmholtz problems over a couple hundred
cores. My only logical explanation for this behavior is that the
communication buffers grow proportional to the number of processes on each
process, but I stress that this is just a guess. I tried reading through the
MUMPS code and quickly gave up.
Another problem with MUMPS is that requires the entire set of right-hand
sides to reside on the root process...that will clearly not work for a
billion degrees of freedom with several hundred RHSs. WSMP gets this part
right and actually distributes those vectors.
Jack
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110816/2aeeeabf/attachment.html>
