[petsc-dev] Monitor changes
Sun Aug 14 19:26:22 CDT 2011
On Sun, Aug 14, 2011 at 19:16, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  In the current model we simply change some KSP options so the next time it
> runs it computes those additional things. So this is no different then
> putting into the code, for example, if timestep == 29
> KSPSetComputeSingularValues().  Note that this does change the flow of the
> running code.
>    In an alternative model, much more thready, it would trigger additional
> threads to do this "other stuff" while leaving the main thread running along
> as it does now. The nice thing about this model is the main code base
> doesn't need to know about all these cool new things that can be computed,
> the drawback is more sophisticated design of everything ....
Yeah, this is the distinction I was thinking of. If the AMS client (or some
other thread) was going to go solve the reduced eigenvalue problem, this
might suggest a more AMSy approach instead of up-front computing plus a dumb
viewer.
>  It's not the files that matter, it is the ability to write code that
> manipulates code rather than every code change being someone using an editor
> to touch source code directly.
And then PETSc was reimplemented in PLT Racket and never seen or heard from
again, although graduate students still tell legends of the fantastic things
that it could do.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110814/ecb70af1/attachment.html>
