[petsc-dev] Monitor changes
Jed Brown
jedbrown at mcs.anl.gov
Sun Aug 14 12:15:32 CDT 2011
On Sun, Aug 14, 2011 at 12:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Well, you are argeeing with me. Publishing an object with AMS is
> different than viewing them and so AMS publishing is not a subclass of
> PetscViewer it is a separate thing.
1. I thought AMS was normally allowed to look at it later (because it
returned a memory reference). By what mechanism does AMS become synchronous
(because it must if you publish a stack variable which will only be valid
instantaneously).
2. We could create an "AMS" viewer that, instead of actually reading the
published values with a separate process, printed it (or wrote to a file).
I need to go use AMS for something so that I can have an intelligent
discussion about its implementation/capability.
> You mean "change the AMS API"? Godzooks you are asking too much :-(
> Reason, this information has to be propagated through all the AMS code
> which scares me too much to consider.
Alternative rationale: AMS does not have a big network of dependencies yet
so now is the best time to make it just how we eventually want it. Getting
hands dirty in AMS (although this may be a somewhat superficial change)
would be useful for me anyway.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110814/e75b7e43/attachment.html>
