[petsc-dev] [petsc-users] Ordering of preallocation and OwnershipRange
Barry Smith
bsmith at mcs.anl.gov
Sun Aug 14 11:58:43 CDT 2011
On Aug 13, 2011, at 11:44 PM, Matthew Knepley wrote:
> On Sat, Aug 13, 2011 at 10:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The PetscLayout object is used to manage default layout among processes so you can create a PetscLayout object and use that to determine how the Mat and Vec objects will be laid out. From the manual page
> Okay, are we recommending that users use PetscLayout now?
As the manual page notes: "it is recommended they not be used in user codes unless you really gain something in their use."
If the user is doing the preallocation (not using a DM) then it makes sense for them to decide how many unknowns are assigned to each process and it doesn't make sense for them to use PetscLayout to figure it out so ones who use this in their code are in this strange very small group of people.
Barry
Note: if someone wants to enhance the code so that one can call MatGetOwnershipRange() before preallocation that is fine, but don't introduce bugs :-)
> Matt
> PetscLayoutCreate - Allocates PetscLayout space and sets the map contents to the default.
> Collective on MPI_Comm
> Input Parameters:
> + comm - the MPI communicator
> - map - pointer to the map
> Level: developer
> Notes: Typical calling sequence
> PetscLayoutCreate(MPI_Comm,PetscLayout *);
> PetscLayoutSetBlockSize(PetscLayout,1);
> PetscLayoutSetSize(PetscLayout,n) or PetscLayoutSetLocalSize(PetscLayout,N);
> PetscLayoutSetUp(PetscLayout);
> PetscLayoutGetSize(PetscLayout,PetscInt *); or PetscLayoutGetLocalSize(PetscLayout,PetscInt *;)
> PetscLayoutDestroy(PetscLayout);
> The PetscLayout object and methods are intended to be used in the PETSc Vec and Mat implementions; it is
> Fortran Notes:
> Not available from Fortran
> On Aug 13, 2011, at 10:28 AM, Matthew Knepley wrote:
> > On Sat, Aug 13, 2011 at 2:57 PM, Josh Hykes <jmhykes at ncsu.edu> wrote:
> > Hello,
> > I'm just starting to experiment with PETSc (v3.1), and I like the Python bindings provided by petsc4py (v1.1.2). So far things seem fairly straightforward, but I'm stumped on a small issue.
> > While creating a parallel AIJ matrix, I'd like to preallocate it using arrays d_nnz and o_nnz. As I understand it, these arrays correspond to the processor's local rows.
> > Currently I specify the global matrix size, and let PETSc decide on the decomposition of the rows. I'd like to ask PETSc what rows each processor has with the getOwnershipRange() function, and then do the preallocation. However, according to the error message
> > > [1] MatAnyAIJSetPreallocation() line 393 in petsc4py-1.1.2/src/include/custom.h
> > > [1] Operation done in wrong order
> > > [1] matrix is already preallocated
> > I'm not allowed to do it in this order.
> > Thus, my question is: is it possible to let PETSc figure out the row decomposition while still using d_nnz and o_nnz for the preallocation? I figure that I could resolve the problem by doing my own decomposition, but it'd be nice if I could let those details up to PETSc.
> > You are correct. We require that preallocation is done at the same time as decomposition. There
> > are tricky dependencies in matrix creation. However, an easy workaround is to create a Vec at
> > the same time with the same global size, since it is guaranteed to have the same layout. I will look
> > into simplifying this if it is possible.
> > Thanks,
> > Matt
> > I'm including an example using petsc4py of what I'd like to do, run with 2 MPI processes.
> > I apologize if this is a dumb question. Thank you for your help.
> > -Josh
> > from petsc4py import PETSc as petsc
> > M, N = 4, 6
> > global_d_nnz = [2, 1, 1, 2]
> > global_o_nnz = [1, 3, 2, 1]
> > A = petsc.Mat()
> > A.create(petsc.COMM_WORLD)
> > A.setSizes([M, N])
> > A.setType('aij')
> > i_start, i_end = A.getOwnershipRange()
> > A.setPreallocationNNZ([global_d_nnz[i_start:i_end],
> > global_o_nnz[i_start:i_end]]) # error occurs here
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> -- Norbert Wiener
