[petsc-dev] Two questions about PC Object
Matthew Knepley
knepley at gmail.com
Sun Aug 7 21:26:54 CDT 2011
On Mon, Aug 8, 2011 at 2:17 AM, Gabriele Jost <gjost at tacc.utexas.edu> wrote:
> Hello!
> I am working with a user of XSEDE (forerly know as TeraGrid) on
> converting his code from Scalapack to using PETSc. His physical problem
> yields matrices which are sparse, but the structure is rather general.
> We have a version going that works very well for one type of problems. I
> can use MUMPS or SuperLU and I get results which are pretty close to what he
> gets when using Scalapack.
> However, I am running into problems with the matrices that correspond to a
> different problem type. I get results when using MUMPS, but they differ
> widely from the Scalapack results. With MUMPS I get an error like:
> Error reported by MUMPS in numerical factorization phase: INFO(1)=-1,
> INFO(2)=359
> I noticed that for the matrix types where I get good results, the
> nonzeros reported for the PC Object type exactly the number of entries in my
> input data for the matrix (MPIAIJ format). For the type that does not work,
> petsc reports more nonzeros than what I enter. The message looks like this:
> linear system matrix = precond matrix:
> Matrix Object:
> type=mpiaij, rows=123120, cols=123120
> total: nonzeros=59094408, allocated nonzeros=59173613
> My questions are:
> 1) Does anybody know what the error INFO(1)=-1 means in MUMPS?
-1 means the error code is in INFO(2). I cannot find any online list of the
error codes. I suggest mailing the MUMPS list.
Matt
> 2) How does PETSc calculate the number of nonzeros for the PC matrix?
> Have banging my head against this problem for a while. Any advice is
> highly appreciated.
> Many thanks in advance!
> Gabriele Jost
> Texas Advanced Computing Center
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110808/2eea31d1/attachment.html>
