[petsc-dev] failing test
Barry Smith
bsmith at mcs.anl.gov
Fri Apr 29 21:28:07 CDT 2011
I also cannot reproduce the problem using shared libraries and mpich2-1.3.1 Suggest trying to reproduce the problem with another MPI implementation.
Barry
Also runs valgrind clean
On Apr 29, 2011, at 9:34 AM, Lisandro Dalcin wrote:
> On 29 April 2011 00:36, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> Lisandro :
>> Has this been fixed? I cannot reproduce it on petsc machine or my Mac.
>> Hong
> Still failing here (shared lib build, using mpich2 1.2.1p1 from Fedora 13)
>>> Can any one take a look here? It is unlikely that is is caused by my
>>> commit "dbddbea75f68". It smells as an issue with Viewers created on
>>> subcommunicators.
>>> [dalcinl at trantor tutorials]$ cd $PETSC_DIR/src/ksp/ksp/examples/tutorials
>>> [dalcinl at trantor tutorials]$ make runex2_bjacobi_2
>>> 42a43,56
>>>> [0]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>>>> [0]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>>>> [0]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>>>> [0]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>>> [0]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>>> [0]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>>>> [1]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>>>> [1]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>>>> [1]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>>>> [1]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>>> [1]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>>>> [1]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>>>> rank 0 in job 7851 trantor_56062 caused collective abort of all ranks
>>>> exit status of rank 0: return code 0
>>> Possible problem with ex2_bjacobi_2, diffs above
>>> Lisandro Dalcin
>>> CIMEC (INTEC/CONICET-UNL)
>>> Predio CONICET-Santa Fe
>>> Colectora RN 168 Km 472, Paraje El Pozo
>>> 3000 Santa Fe, Argentina
>>> Tel: +54-342-4511594 (ext 1011)
>>> Tel/Fax: +54-342-4511169
> Lisandro Dalcin
