[petsc-dev] failing test
Hong Zhang
hzhang at mcs.anl.gov
Thu Apr 28 22:36:56 CDT 2011
Lisandro :
Has this been fixed? I cannot reproduce it on petsc machine or my Mac.
Hong
> Can any one take a look here? It is unlikely that is is caused by my
> commit "dbddbea75f68". It smells as an issue with Viewers created on
> subcommunicators.
> [dalcinl at trantor tutorials]$ cd $PETSC_DIR/src/ksp/ksp/examples/tutorials
> [dalcinl at trantor tutorials]$ make runex2_bjacobi_2
> 42a43,56
>> [0]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>> [0]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>> [0]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>> [0]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>> [0]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>> [0]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>> [1]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
>> [1]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
>> [1]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
>> [1]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>> [1]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
>> [1]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
>> rank 0 in job 7851 trantor_56062 caused collective abort of all ranks
>> exit status of rank 0: return code 0
> Possible problem with ex2_bjacobi_2, diffs above
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
