[petsc-dev] failing test
Lisandro Dalcin
dalcinl at gmail.com
Thu Apr 28 16:38:11 CDT 2011
Can any one take a look here? It is unlikely that is is caused by my
commit "dbddbea75f68". It smells as an issue with Viewers created on
subcommunicators.
[dalcinl at trantor tutorials]$ cd $PETSC_DIR/src/ksp/ksp/examples/tutorials
[dalcinl at trantor tutorials]$ make runex2_bjacobi_2
42a43,56
> [0]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
> [0]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
> [0]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
> [0]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
> [0]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
> [0]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
> [1]PETSC ERROR: PetscCommDestroy() line 243 in /home/devel/petsc/dev/src/sys/objects/tagm.c
> [1]PETSC ERROR: PetscHeaderDestroy_Private() line 107 in /home/devel/petsc/dev/src/sys/objects/inherit.c
> [1]PETSC ERROR: PetscViewerDestroy() line 109 in /home/devel/petsc/dev/src/sys/viewer/interface/view.c
> [1]PETSC ERROR: PetscObjectDestroy() line 73 in /home/devel/petsc/dev/src/sys/objects/destroy.c
> [1]PETSC ERROR: PetscObjectRegisterDestroyAll() line 215 in /home/devel/petsc/dev/src/sys/objects/destroy.c
> [1]PETSC ERROR: PetscFinalize() line 1032 in /home/devel/petsc/dev/src/sys/objects/pinit.c
> rank 0 in job 7851 trantor_56062 caused collective abort of all ranks
> exit status of rank 0: return code 0
Possible problem with ex2_bjacobi_2, diffs above
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
