[petsc-dev] change to MatIsTranspose() and failing test
Lisandro Dalcin
dalcinl at gmail.com
Wed Apr 27 14:04:18 CDT 2011
After wasting as considerable amount of time debugging issues related
to uninitialized variables passed to MatIsTranspose, I've pushed this:
changeset: 18869:3bdc748ba073
tag: tip
user: Lisandro Dalcin <dalcinl at gmail.com>
date: Wed Apr 27 15:59:56 2011 -0300
summary: MatIsTranspose(): error if any matrix does not support the test
And now, the best below fails, becase SeqBAIJ does not support transpose test.
[dalcinl at trantor tests]$ cd $PETSC_DIR/src/ksp/ksp/examples/tests
[dalcinl at trantor tests]$ make runex32_aij_sbaij_icc
make: [runex32_aij_sbaij_icc] Error 56 (ignored)
1,19c1,7
< [0]PETSC ERROR: --------------------- Error Message
< [0]PETSC ERROR: No support for this operation for this object type!
< [0]PETSC ERROR: Matrix of type <seqbaij> does not support checking
for transpose!
< [0]PETSC ERROR:
< [0]PETSC ERROR: Petsc Development HG revision:
a02bb9bcaf33cf16868e2771c3c8306d52235c69 HG Date: Fri Apr 22 13:15:40
2011 -0500
< [0]PETSC ERROR: See docs/changes/index.html for recent updates.
< [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
< [0]PETSC ERROR: See docs/index.html for manual pages.
< [0]PETSC ERROR:
< [0]PETSC ERROR: ./ex32 on a arch-linu named trantor by dalcinl Wed
Apr 27 16:00:08 2011
< [0]PETSC ERROR: Libraries linked from
/home/devel/petsc/dev/arch-linux2-c-debug/lib
< [0]PETSC ERROR: Configure run at Sat Apr 23 17:40:22 2011
< [0]PETSC ERROR: Configure options --with-shared-libraries=1
PETSC_ARCH=arch-linux2-c-debug
< [0]PETSC ERROR:
< [0]PETSC ERROR: MatIsTranspose() line 4383 in
/home/devel/petsc/dev/src/mat/interface/matrix.c
< [0]PETSC ERROR: main() line 69 in src/ksp/ksp/examples/tests/ex32.c
< application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
< rank 0 in job 3534 trantor_56062 caused collective abort of all ranks
< exit status of rank 0: return code 56
> 0 KSP Residual norm 0.210648
> 1 KSP Residual norm 0.07826
> 2 KSP Residual norm 0.0115565
> 3 KSP Residual norm 0.00113989
> 4 KSP Residual norm 0.00013248
> 5 KSP Residual norm 9.04476e-06
> 6 KSP Residual norm 4.52149e-07
Possible problem with ex32_aij_sbaij_icc, diffs above
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
