[petsc-dev] Floating point exception in ex47cu.cu
Евгений Козлов
neoveneficus at gmail.com
Fri Apr 22 11:22:27 CDT 2011
Hello,
I am interesting in using PETSc for iterative solving sparse linear
system on multi-GPU systems.
First of all, I compiled PETSc-dev and tried to run some examples,
which will run on GPU.
I found src/snes/examples/tutorials/ex47cu.cu. It was compiled and executed.
Out of original program src/snes/examples/tutorials/ex47cu.cu:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: User provided compute function generated a Not-a-Number!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
d3e10315d68b1dd5481adb2889c7d354880da362 HG Date: Wed Apr 20 21:03:56
2011 -0500
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ex47cu on a arch-linu named cn03 by kukushkinav Fri
Apr 22 18:33:32 2011
[0]PETSC ERROR: Libraries linked from /home/kukushkinav/lib
[0]PETSC ERROR: Configure run at Thu Apr 21 19:18:22 2011
[0]PETSC ERROR: Configure options --prefix=/home/kukushkinav
--with-blas-lapack-dir=/opt/intel/composerxe-2011.0.084/mkl
--with-mpi-dir=/opt/intel/impi/4.0.1.007/intel64/bin --with-cuda=1
--with-cusp=1 --with-thrust=1
--with-thrust-dir=/home/kukushkinav/include
--with-cusp-dir=/home/kukushkinav/include
[0]PETSC ERROR:
[0]PETSC ERROR: SNESSolve_LS() line 167 in src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 2407 in src/snes/interface/snes.c
[0]PETSC ERROR: main() line 38 in src/snes/examples/tutorials/ex47cu.cu
application called MPI_Abort(MPI_COMM_WORLD, 72) - process 0
Then I tried to find the place in source with the problem, I changed
the function in struct ApplyStencil to
void operator()(Tuple t) { thrust::get<0>(t) = 1; }
Result:
[0]PETSC ERROR: Infinite or not-a-number generated in mdot, entry 0!
[0]PETSC ERROR:
2011 -0500
[0]PETSC ERROR:
[0]PETSC ERROR: ex47cu on a arch-linu named cn11 by kukushkinav Fri
Apr 22 18:58:04 2011
[0]PETSC ERROR:
[0]PETSC ERROR: VecMDot() line 1146 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: KSPGMRESClassicalGramSchmidtOrthogonalization() line
66 in src/ksp/ksp/impls/gmres/borthog2.c
[0]PETSC ERROR: GMREScycle() line 161 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve_GMRES() line 244 in src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve() line 426 in src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: SNES_KSPSolve() line 3107 in src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_LS() line 190 in src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 2407 in src/snes/interface/snes.cС уважением,
Евгений
RedHat 5.5, Cuda 3.2
Question1: Is it my problem or a bug of the algorithm?
Question2: Where can I find simple doc or example, which describe how
to solve sparse linear systems on multi-GPU systems using PETSc?
Best regards,
Eugene
