[petsc-dev] PetscViewerASCIISynchronizedAllow
    Jed Brown
    jed at 59A2.org
    Thu Apr 21 10:05:18 CDT 2011
On Thu, Apr 21, 2011 at 17:03, Jed Brown <jed at 59a2.org> wrote:
> Currently this needs to be called, but is not available from Fortran and is
> marked as developer level. Is there a plan to make it somehow automatic (I
> thought the function was introduced because it was expensive to do it
> automatically), or did someone forget to make Fortran bindings and set the
> Level?
And should this have a push and pop model. Otherwise I still need a getter
to do a synchronized view within a library call and leave the viewer in the
same state as the user gave it to me in.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110421/8e1d0fa9/attachment.html>
