[petsc-dev] [petsc-users] FETI-DP
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Wed Apr 20 10:05:59 CDT 2011
Jed Brown wrote:
> I'm confuse because in the work of Klawoon/Rheinbach, it is
> claimed that the following operator can be solved in a pure local way:
> F = \sum_{i=1}^{N} B^i inv(K_BB^i) trans(B^i)
> Did they use "F" for this thing? Usually F is the FETI-DP operator
> which involves a Schur complement of the entire partially assembled
> operator in the dual space. In any case, this thing is not purely
> local since the jump operators B^i need neighboring values so it has
> the same communication as a MatMult.
"F" is here the usual FETI-DP operator. I just omitted the coarse space
part for more readability.
> With B^i the jump operators and K_BB^i the discretization of the
> sub domains with the primal nodes.
> I think you mean "with the primal nodes removed".
Yes!
> From the notation it follows that EACH local solve takes the whole
> vector of Lagrange multipliers. But this is not applicable for a
> good parallel implementation. Any hint on this topic would be
> helpful for me to understand this problem.
> I can't tell from their papers how B is stored. It would be natural to
> simply store B as a normal assembled matrix with a standard row
> partition of the Lagrange multipliers. Then you would apply the
> subdomain solve operator using
> MatMultTranspose(B,XLambdaGlobal,XGlobal);
> for (i=0; i<nlocalsub; i++) {
> Vec XSubdomain,YSubdomain;
> VecGetSubVector(XGlobal,sublocal[i],&XSubdomain); // no copy if
> subdomains are contiguous
> VecGetSubVector(YGlobal,sublocal[i],&YSubdomain); // also no copy
> KSPSolve(kspK_BB[i],XSubdomain,YSubdomain); // purely local solve,
> often KSPPREONLY and PCLU
> VecRestoreSubVector(XGlobal,sublocal[i],&XSubdomain);
> VecRestoreSubVector(YGlobal,sublocal[i],&YSubdomain);
> MatMult(B,YGlobal,YLambdaGlobal);
> All the communication is in the MatMultTranspose and MatMult. The
> "Global" vectors here are global with respect to K_BB (interior and
> interface dofs, primal dofs removed). I don't think there is need to
> ever store K_BB as a parallel matrix, it would be a separate matrix
> per subdomain (in the general case, subdomains could be parallel on
> subcommunicators).
> This code should handle nlocalsub subdomains owned by the local
> communicator, typically PETSC_COMM_SELF. The index sets (IS) in
> sublocal represent the global (space of K_BB) dofs, usually these are
> contiguous sets so they can be represented very cheaply.
Following the mathematical representation wouldn't make it more sense to
store B but B^T, because the local matrices B_i^T are real local and
would have no off-diagonal elements? Also the very first multiplication
MatMult(B,XLambdaGlobal,XGlobal) could be done in a local way. But I'm
not sure what will than happen with the very last matrix multiplication,
MatMultTranspose(B,YGlobal,YLambdaGlobal). Would it potentially result
in an all-to-all communication?
