[petsc-dev] [petsc-maint #69143] petsc-dev performance issues
    Barry Smith
    bsmith at mcs.anl.gov
    Mon Apr 18 10:32:57 CDT 2011
   If anyone has started work on fixing this, please let me know. Otherwise I'll start shortly.
   Barry
On Apr 18, 2011, at 8:24 AM, Barry Smith wrote:
>   Matt,
>     Yes, this is the problem.  Since we cannot know if anyone has called a PetscSynchronizedPrintf() it has to call this flush to be safe and that, to be safe, has to have the extra message passing. Even if we handle 1,000 processes at a time, with 100,000 processes it will take 100 stages which is too long.
>     I think we have to do a major rearchitecturing.  Maybe we want to have a flag (set to false by default) in each ASCII viewer indicating that it has synchronize prints. When the flag is false it skips the entire flush and if a synchronize print is done it generates an error. We'll that is easily done.
>    Barry
> On Apr 18, 2011, at 8:10 AM, Matthew Knepley wrote:
>> On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <steiger at purdue.edu>wrote:
>>> On 4/18/2011 7:25 AM, Matthew Knepley wrote:
>>>> On Sun, Apr 17, 2011 at 11:59 PM, Sebastian Steiger <steiger at purdue.edu
>>>> 17631 is in
>>>> PetscSynchronizedFlush(), a routine which is not called from
>>>> KSPMonitorDefault()
>>>> --->  PetscViewerASCIIMonitorPrintf()
>> I am looking over the code, and I think that change is going to be bad for
>> everyone
>> because we have
>> PetscViewerFlush_ASCII()
>> --> PetscSynchronizedFlush()
>>      --> ping-pong between 0 and everyone
>> Anytime someone calls flush, the process cannot just send 0 and move on, it
>> has
>> to wait.
>>   Matt
>>>> and thus would not change the performance. My guess is that you have
>>> another
>>>> print statement using PetscSynchronizedPrintf/Flush() somewhere in the
>>> code.
>>>>   Matt
>>> In addition to the KSPMonitor, I've hooked up the petsc output with my
>>> own output system as it is written on the webpage:
>>> PetscErrorCode my_double_petsc_vfprintf(FILE * fd, const char format[],
>>> va_list Argp)
>>>      PetscErrorCode ierr;
>>>      //PetscFunctionBegin; // <ss> gave problems in petsc-3.2 - not
>>> essential according to Barry and Matt
>>>      if (fd != stdout && fd != stderr) { /* handle regular files */
>>>              ierr = PetscVFPrintfDefault(fd,format,Argp);
>>> PetscMatrixNemo<double>::check_petsc_error(ierr);
>>>      } else {
>>>              char buff[2000];
>>> #if PETSC_VERSION_RELEASE == 1
>>>               int length;
>>> #else
>>>              size_t length;
>>> #endif
>>>              ierr = PetscVSNPrintf(buff, 2000, format, &length, Argp);
>>>              /* now send buff to whatever stream or whatever you want */
>>>              msg << buff;
>>>              // flush buffer every 2nd time
>>>              num_double_petsc_lines++;
>>>              if (num_double_petsc_lines==2) {
>>>                      msg.flush();
>>>                      num_double_petsc_lines = 0;
>>>      //PetscFunctionReturn(0);
>>>      return 0;
>>> Is that connected to the problem? Please note that the "flush buffer
>>> every 2nd time" does not cause the problems, as it is on my side.
>>> Sebastian
>>>>   Sebastian
>>>>   On 4/17/2011 9:16 PM, Barry Smith wrote:
>>>>> On Apr 17, 2011, at 8:11 PM, Matthew Knepley wrote:
>>>>>> On Sun, Apr 17, 2011 at 8:05 PM, Barry Smith <bsmith at mcs.anl.gov
>>>>   <mailto:bsmith at mcs.anl.gov>> wrote:
>>>>>> I don't understand, what is different and why does it slow
>>>>   everything down?
>>>>>> You introduced a ping-pong between 0 and every process for every
>>>>   call to
>>>>>> PetscSynchronizedFlush() in order to "stop a flood of messages to
>>>>   0". As
>>>>>> process count increases, this is going to be horrible.
>>>>>  Oh yes, this will do it   Is this being used by one of our
>>>>   monitor routines? If so we need to fix our monitors to not use
>>>>   synchronized printf. So what in the code is calling this.
>>>>>> This is just the kind of thing that MPI should be solving for us,
>>>>   instead of us
>>>>>> putting in bullshit code like this to try and regulate message
>>>>   counts. Is there
>>>>>> an MPI construct to manage this?
>>>>>  One could use some kind of all to one to get the messages down
>>>>   to process zero.
>>>>>  Barry
>>>>>>  Matt
>>>>>> Barry
>>>>>> On Apr 17, 2011, at 6:50 PM, Sebastian Steiger wrote:
>>>>>>> Barry, Matt, Satish,
>>>>>>> Found it. r16730 is good, r16731 is bad. Matt was right: when I
>>>>   turn off
>>>>>>> the petsc messages generated by monitoring the iterations of the
>>>>   linear
>>>>>>> solver, then the revisions have comparable speed. When I turn it
>>> on,
>>>>>>> then 16731 is 2-3 times slower.
>>>>>>> Please fix!
>>>>>>> Best
>>>>>>> Sebastian
>>>>>>> On 04/15/2011 07:31 AM, Matthew Knepley wrote:
>>>>>>>> On Thu, Apr 14, 2011 at 11:33 PM, Satish Balay
>>>>   <petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
>>>>   <mailto:petsc-maint at mcs.anl.gov>>> wrote:
>>>>>>>>  It would be good to complete the bisection to confirm - but
>>>>   could it
>>>>>>>>  be this?
>>>>>>>>  http://petsc.cs.iit.edu/petsc/petsc-dev/rev/10be2c80ec26
>>>>>>>>  CHKMEMQ is disabled only with --with-errorchecking=0 - but
>>> the
>>>>>>>>  assumpton for this change was that it would be disabled for
>>>>>>>>  --with-debugging=0 ?
>>>>>>>> This is my bet for bad set:
>>>>>>>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ee1bdc170b4d
>>>>>>>> It introduces new messages, but only of length 1. Is your code
>>>>   printing
>>>>>>>> anything at all
>>>>>>>> during the run?
>>>>>>>> Thanks,
>>>>>>>>    Matt
>>>>>>>>  Satish
>>>>>>>>  On Thu, 14 Apr 2011, Sebastian Steiger wrote:
>>>>>>>>> I'm sorry, actually 16721 is good and 16733 is bad. So it's 12
>>>>>>>>  revisions.
>>>>>>>>> On 4/14/2011 9:12 PM, Sebastian Steiger wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> I've pinned it down to 16 revisions: 16721 is good, 16737 is
>>>>>>>>  bad. The
>>>>>>>>>> next bisection step would be 16727, but from the log I see
>>> that
>>>>>>>>>> 16727-16736 might have some problems. Should I continue or do
>>>>>>>>  you guys
>>>>>>>>>> now have a clue what could cause the factor 2-3 slowdown?
>>>>>>>>>> Sebastian
>>>>    steiger at jaguarpf-login6
>>> :~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$
>>>>   hg
>>>>>>>>>> log -r16721:16737
>>>>>>>>>> changeset:   16721:b788c229de4d
>>>>>>>>>> parent:      16720:9aafffdcf68b
>>>>>>>>>> parent:      16715:e53f46924236
>>>>>>>>>> user:        Jed Brown <jed at 59A2.org>
>>>>>>>>>> date:        Mon Aug 09 17:30:28 2010 -0800
>>>>>>>>>> summary:     merge
>>>>>>>>>> changeset:   16722:4ca941c57754
>>>>>>>>>> user: hong at vis-v410v166.mcs.anl-external.org
>>>>   <mailto:hong at vis-v410v166.mcs.anl-external.org>
>>>>   <mailto:hong at vis-v410v166.mcs.anl-external.org>>
>>>>>>>>>> date:        Tue Aug 10 11:57:11 2010 -0500
>>>>>>>>>> summary:     add case of np=1 for
>>> MatGetMultiProcBlock_MPIAIJ()
>>>>>>>>>> changeset:   16723:4d6b54981472
>>>>>>>>>> date:        Tue Aug 10 12:00:14 2010 -0500
>>>>>>>>>> summary:     fix memory leak in MatHeaderCopy() and
>>>>>>>>  MatHeaderReplace()
>>>>>>>>>> changeset:   16724:2680bde1c9b8
>>>>>>>>>> user: Shri at mcswl165.mcs.anl.gov
>>>>   <mailto:Shri at mcswl165.mcs.anl.gov> <mailto:Shri at mcswl165.mcs.anl.gov
>>>>   <mailto:Shri at mcswl165.mcs.anl.gov>>
>>>>>>>>>> date:        Thu Aug 12 14:37:43 2010 -0500
>>>>>>>>>> summary:     Started adding semismooth stuff.
>>>>>>>>>> changeset:   16725:50dceda7151c
>>>>>>>>>> date:        Thu Aug 12 14:45:13 2010 -0500
>>>>>>>>>> summary:     Defined Infinity and epsilon
>>>>>>>>>> changeset:   16726:c0f1b46d675f
>>>>>>>>>> user:        hzhang
>>>>>>>>>> date:        Fri Aug 13 11:10:37 2010 -0500
>>>>>>>>>> summary:     update outputfiles for nightly tests
>>>>>>>>>> changeset:   16727:67df4fdba5bd
>>>>>>>>>> user: hong at hzhangmac.mcs.anl.gov
>>>>   <mailto:hong at hzhangmac.mcs.anl.gov>
>>>>   <mailto:hong at hzhangmac.mcs.anl.gov>>
>>>>>>>>>> date:        Fri Aug 13 13:25:56 2010 -0500
>>>>>>>>>> summary:     add PetscSubcommType in PetscSubcommCreate(); add
>>>>>>>>>> PetscSubcommCreate_contiguous().
>>>>>>>>>> changeset:   16728:10be2c80ec26
>>>>>>>>>> parent:      16723:4d6b54981472
>>>>>>>>>> user:        Barry Smith bsmith at mcs.anl.gov
>>>>>>>>  <mailto:bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>>>>>>>>> date:        Tue Aug 10 18:15:10 2010 -0500
>>>>>>>>>> summary:     merged CHKMEMQ; into PetscStackPush() and
>>>>>>>>  PetscStackPop()
>>>>>>>>>> changeset:   16729:ef8e7a4583e6
>>>>>>>>>> date:        Thu Aug 12 14:16:40 2010 -0500
>>>>>>>>>> summary:     changed MatHeaderCopy() to MatHeaderMerge() and
>>>>>>>>  improved
>>>>>>>>>> comment
>>>>>>>>>> changeset:   16730:50055ed8b725
>>>>>>>>>> parent:      16729:ef8e7a4583e6
>>>>>>>>>> parent:      16725:50dceda7151c
>>>>>>>>>> date:        Thu Aug 12 16:24:48 2010 -0500
>>>>>>>>>> summary:     commit after merge
>>>>>>>>>> changeset:   16731:ee1bdc170b4d
>>>>>>>>>> date:        Fri Aug 13 13:50:30 2010 -0500
>>>>>>>>>> summary:     minor formating of short lines
>>>>>>>>>> changeset:   16732:a49d9a4b41bc
>>>>>>>>>> parent:      16731:ee1bdc170b4d
>>>>>>>>>> parent:      16727:67df4fdba5bd
>>>>>>>>>> date:        Fri Aug 13 13:50:43 2010 -0500
>>>>>>>>>> changeset:   16733:804ce43d15c9
>>>>>>>>>> date:        Fri Aug 13 11:01:24 2010 -0800
>>>>>>>>>> summary:     Update converged reason for Rosenbrock demo to be
>>>>>>>>  more portable
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to
>>>>   which
>>>>>>>> their experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> <bisection-conclusion.txt>
>>>>   experiments is infinitely more interesting than any results to which
>>>>>> -- Norbert Wiener
>>>> -- Norbert Wiener
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
>> On Mon, Apr 18, 2011 at 7:52 AM, Sebastian Steiger <steiger at purdue.edu> wrote:
>>> <mailto:steiger at purdue.edu>> wrote:
>>>    On a side note, why did that PetscPrintf function not show up in the log
>>>    summary? That could have spared me the whole bisection process.
>>> I cannot make sense of the problem from your report. The only change in
>>> 17631 is in
>>>  KSPMonitorDefault()
>> I am looking over the code, and I think that change is going to be bad for everyone
>> because we have
>> Anytime someone calls flush, the process cannot just send 0 and move on, it has
>> to wait.
>>    Matt
>>> and thus would not change the performance. My guess is that you have another
>>> print statement using PetscSynchronizedPrintf/Flush() somewhere in the code.
>>>    Matt
>> va_list Argp)
>>       } else {
>>               char buff[2000];
>>               int length;
>> #else
>>               size_t length;
>> #endif
>>               msg << buff;
>>                       msg.flush();
>>       return 0;
>> Sebastian
>>>    Sebastian
>>>    everything down?
>>>    call to
>>>    0". As
>>>    instead of us
>>>    counts. Is there
>>>    to process zero.
>>>>   Barry
>>>>>   Matt
>>>>>  Barry
>>>    turn off
>>>    linear
>>>>>> solver, then the revisions have comparable speed. When I turn it on,
>>>>>> Please fix!
>>>>>> Best
>>>>>> Sebastian
>>>    could it
>>>>>>>   be this?
>>>>>>>   CHKMEMQ is disabled only with --with-errorchecking=0 - but the
>>>    printing
>>>>>>> anything at all
>>>>>>> during the run?
>>>>>>>  Thanks,
>>>>>>>     Matt
>>>>>>>   Satish
>>>>>>>   revisions.
>>>>>>>>> Hi,
>>>>>>>   bad. The
>>>>>>>>> next bisection step would be 16727, but from the log I see that
>>>>>>>   you guys
>>>>>>>>> Sebastian
>>>     steiger at jaguarpf-login6:~/src/app-nemo/NEMO/libs/petsc-dev/petsc-dev$
>>>    hg
>>>>>>>>> log -r16721:16737
>>>>>>>>> summary:     merge
>>>>>>>>> summary:     add case of np=1 for MatGetMultiProcBlock_MPIAIJ()
>>>>>>>   MatHeaderReplace()
>>>>>>>>> user:        hzhang
>>>>>>>   PetscStackPop()
>>>>>>>   improved
>>>>>>>>> comment
>>>>>>>   more portable
>>>    which
>>>>>>> -- Norbert Wiener
>>>>> -- Norbert Wiener
>>> -- Norbert Wiener
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
